Hi Everyone,
I have been given a script by JAMF to help with adding users to the FileVault list at login via a policy, we have a epic amount of Freelancers and they are not always the type to bring the machine back to have themselves enabled, they will then go on a shoot/leave the building and cannot access the machine.
Here is what I got from JAMF:
# Copyright (c) 2013, JAMF Software, LLC. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of the JAMF Software, LLC nor the
# names of its contributors may be used to endorse or promote products
# derived from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
# DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
# ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# Description
# This script was designed to enable the currently logged in user's account the ability to unlock
# a drive that was originally encrypted with the management account using a policy from the JSS.
# The script will prompt the user for their credentials.
# This script was designed to be run via policy at login or via Self Service. The encryption
# process must be fully completed before this script can be successfully executed.
# HISTORY
# -Created by Bryson Tyrrell on November 5th, 2012
# -Updated by Sam Fortuna on July 31, 2013
# -Improved Error Handling
## Self Service policy to add the logged in user to the enabled list
## of FileVault 2 users.
## Pass the credentials for an admin account that is authorized with FileVault 2
adminName=$4
adminPass=$5
if [ "${adminName}" == "" ]; then
echo "Username undefined. Please pass the management account username in parameter 4"
exit 1
if [ "${adminPass}" == "" ]; then
echo "Password undefined. Please pass the management account password in parameter 5"
exit 2
## Get the logged in user's name
userName=logname
## This first user check sees if the logged in account is already authorized with FileVault 2
userCheck=fdesetup list | awk -v usrN="$userName" -F, 'index($0, usrN) {print $1}'
if [ "${userCheck}" == "${userName}" ]; then
echo "This user is already added to the FileVault 2 list."
exit 3
## Check to see if the encryption process is complete
encryptCheck=fdesetup status
statusCheck=$(echo "${encryptCheck}" | grep "FileVault is On.")
expectedStatus="FileVault is On."
if [ "${statusCheck}" != "${expectedStatus}" ]; then
echo "The encryption process has not completed, unable to add user at this time."
exit 4
## Get the logged in user's password via a prompt
echo "Prompting ${userName} for their login password."
userPass="$(osascript -e 'Tell application "System Events" to display dialog "Please enter your login password:" default answer "" with title "Login Password" with text buttons {"Ok"} default button 1 with hidden answer' -e 'text returned of result')"
echo "Adding user to FileVault 2 list."
## This "expect" block will populate answers for the fdesetup prompts that normally occur while hiding them from output
expect -c "
log_user 0
spawn fdesetup add -usertoadd $userName
expect "Enter the primary user name:"
send ${adminName}
expect "Enter the password for the user '$adminName':"
send ${adminPass}
expect "Enter the password for the added user '$userName':"
send ${userPass}
log_user 1
expect eof
## This second user check sees if the logged in account was successfully added to the FileVault 2 list
if [ "${userCheck}" != "${userName}" ]; then
echo "Failed to add user to FileVault 2 list."
exit 5
echo "${userName} has been added to the FileVault 2 list."
And this is what I am getting from the logs when it runs:
Executing Policy FVUserEnable...
Mounting ldnlwwjss01.emea.corp.ipgnetwork.com to /Volumes/CasperShare...
Running script addCurrentUser.sh...
Script exit code: 5
Script result: Prompting room.one for their login password.
Error: Authentication of FileVault failed.
It seems to be failing when trying to return the user password saying that authentication failed, I have added the admin username and password into the JAMF policy on parameter 4/5 which is where I am assuming that adminName and adminPass are getting their info from.
Any help would be awesome! Thanks!
