Jamf Remote - Enable SSH for specific user. What user account does remote use?
  • August 10, 2017
  • 14 views
I like to use Jamf Remote however i would like to set it up on machines to allow access for specific users.
So my question is, what users do i need to add to remote login for Jamf to work?
I believe jamf uses casperscreensharing or something similar but you can't add that via the gui as it's not a real user so perhaps if i added it by terminal or a script.
But is that the correct user to be adding to allow Jamf Remote to connect?
Thanks.
1 reply
sdagley
  • 3567 replies
  • August 10, 2017
@CJeffery You define the username for the Casper Management Account either when you build your QuickAdd package or by setting up User-Initiated Enrollment in your JSS.
Cookie policy
Cookie settings
