HI,
Does anyone have a working script to add asset numbers to iPad records using a csv file?
We want to scan serial number and asset tag at 1 to 1 rollout, and then upload to put asset number into the iPad record.
Sandy
Script to match iPad Serial Numbers to Asset #s
Best answer by christiandooley
Hi @Sandy
I hope you are doing well. Support has recently come up with and in-house python script that could potentially complete this for you. I recommend you reach out to your technical account manager and we can set something up to look at your environment and see if the script we have on hand will get your asset tags imported to your devices.
Best,
Christian Dooley
JAMF Support
