SentinelOne bash Script
Hi Im tring to implement a bash script trough JAMF to filter SentinelOne's version useing sentinelctl version. Basicaly it gets the version, stores it into a variable and runs it trough an if statment and if the version dosnt match it runs sentinelctl uninstall, but the script is still not working.
Any ideas ?
  • 63 replies
  • February 3, 2021
Can you post a copy of your script and any errors you may be getting?
dbrundage11
  • 4 replies
  • February 4, 2021
This is the Sentinel One script I use in an Extension Attribute.
1#!/bin/sh
2
3# This script will check the status of the SentinelOne Agent
4
5if command -v sentinelctl 1>/dev/null; then
6echo "<result> SentinelOne agent is installed with version
7`sentinelctl version | awk '{print $2}'` and was connected to management
8console `sentinelctl config Server Address | tail -1 | awk '{print $2}'` </result>";
9
10else
11s1_agent=$(ps aux | grep -Ei "sentineld$" | awk '{ print $11 };' |
12grep -v grep)
13
14if [ -z $s1_agent ]; then
15echo "<result>SentinelOne Agent is not Installed.</result>";
16
17else
18s1_agent=$(echo $s1_agent | sed 's|sentineld|
19sentinelctl|g')
20echo "<result>SentinelOne Agent is running but
21could not locate SentinelCtl in the default PATH /usr/local/bin. The full path is - $s1_agent </result>" ;
22
23fi
24
25fi
Cookie policy
Cookie settings
