I read through the documentation and could not find the PURPOSE of such an installation.
I'm assuming, from the name alone, it allows me to deploy root certificates from Active Directory? Is that all it does?
What is AD CS Connector used for? What is it's purpose?
Best answer by tnielsen
Thanks. I have been at the link above many times ... but never clicked "Introduction". Duh
Thanks.
http://docs.jamf.com/technical-papers/jamf-pro/integrating-ad-cs/10.6.0/Overview.html
"Jamf Pro allows you to add Active Directory Certificate Services (AD CS) as a PKI Provider in Jamf Pro. This allows you to use AD CS as the certificate authority (CA) for distributing certificates to computers and mobile devices via configuration profiles. "
