Not sure how many of you have already deployed 10.1.2, but there is a neat new feature that Adobe enabled by default, and that is Print On Both Sides of Paper. Better known as Duplex printing, this feature was buried in the printer settings. Adobe felt that feature need to be on the main print dialog window, and they decided it needed to be on by default. Oh, and right now, there doesn't appear to be a way to disable it and make that disable stick. Or to disable it via script or any other method we might use.
Just wanted to give people a heads up in case you hadn't seen it, or haven't had any help desk tickets rolling in about it.
Steve
