Posted on 04-11-2008 09:46 AM
We've got a test lab of systems that I'm trying to change the wireless settings on. We are changing from a problematic PEAP setup to a PSK environment. Systems are configured with Parental controls and Simple Finder. They are unable to change anything in the Control Panel shy of the screen saver. Building a package to be deployed by Casper grabs the system.keychain file which is bad news for all of our existing systems as pushing a package with this seems to put the target machine in a very difficult to remove loop of removing the keychain, and manually adding in the settings physically on the machine.
Anyone found a way to get around this? I'd basically need to push wireless settings across the command line with a script that uses that password with networksetup or find a way to push the item into the keychain from SSH.
Something like step 4: here has potential except for the fact that it must be run as the currently logged on user and our lab user cant access the Network settings.
http://homepage.mac.com/simx/technonova/C488455530/E20070821192628/index.html
Thanks in advance!
Cory Ranschau
Systems Administrator
Room and Board
W: 763.302.3606
cranschau at roomandboard.com
Posted on 04-11-2008 10:02 AM
check out /System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport......copy to /usr/sbin, use -A, have a beer.
Eric Winkelhake | Technology Services ? Mundocom | Re:Sources IT
35 West Wacker Drive, Suite 3000 | Chicago, IL 60601
Office: 312-220-1669 | Mobile: 312-519-5632
Email: Eric.Winkelhake at us-resources.com
Open a Service Desk Ticket | Navigating IT | Training Now
Posted on 04-11-2008 10:03 AM
what version of OS X?
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
cell: 913-449-7589
office: 913-627-0351
Posted on 04-11-2008 10:09 AM
I have been able to bind using airport -A but rebooting the system reverts it back to not knowing the password. Did I miss a step? (This is currently on 10.4.8).
Posted on 04-11-2008 10:16 AM
ARD has a built in network setup command you can script out and use. In
10.5 they (Apple) relocated the command into /usr/sbin I think...
Here is the full command path
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Support/networksetup
You can script using it, and I have one to modify proxy settings and it
works
Thomas Larkin
TIS Department
KCKPS USD500
tlarki at kckps.org
cell: 913-449-7589
Posted on 04-11-2008 10:27 AM
don't think theres a switch to permanently add it, but whats wrong with hashing the password and making a launchd item or a casper policy for login??
Cory Ranschau <CRanschau at RoomAndBoard.com> 04/11/08 12:09 PM
To
Eric Winkelhake <eric.winkelhake at us-resources.com>
cc
"casper at list.jamfsoftware.com" <casper at list.jamfsoftware.com>,
"casper-bounces at list.jamfsoftware.com"
<casper-bounces at list.jamfsoftware.com>
Subject
Re: [Casper] Changing wireless settings across a number of systems
