response: disable optical audio
SeanA
Contributor III
I was not sure of the answer either, so I inquired with an Apple engineer.
His response was 'this is not a current option that is manageable by MCX
settings or any other known settings.'
This looks like a feature request situation.
Out of curiosity, why would you want to manage (turn off) optical audio?
Sean
Sean Alexander
Macintosh Services Delivery
Lockheed Martin - Enterprise Business Services
817-763-3259 (desk)
817-655-9153 (fax)
3 REPLIES 3
Not applicable
In my experience, this is a hardware malfunction. The combined analog-optical audio jacks (in and out) have a trigger to detect which type of cable (1/8" or toslink) has been connected. AFAIK, that's purely a hardware switch. Once that's detected, the OS flips the audio output to that type (you'll see the setting in System Preferences change over from built-in speakers to headphones or optical, with no other options or way to switch it back). Typically, this gets triggered over to the optical audio and won't come back. Occasionally this is fixable by cleaning out the port or using the toothpick trick to nudge the switch. If that doesn't work, the next step is usually to replace the malfunctioning component (which may be built into the main logic board depending on the model).
Where am I going with all of this in regards to Casper? If it's an unfixed hardware issue, I don't think you're ever going to get analog output even if you manage to disable just the optical audio in software (you'll just have no audio). If the red light shining out of the audio jack is troublesome, you might look at disabling sound entirely. If you need analog audio, a USB dongle is probably your best bet.
My two cents.
-Charlie
Charlie Smith
Desktop Engineer
Information Services Department (ISD)
MIT Lincoln Laboratory
244 Wood St. Lexington, MA 02420
Phone: 781.981.0854
E-mail: charlie.smith at ll.mit.edu
jarednichols
Honored Contributor
I would think so users don't get stuck in the optical out mode. No?
j
Jared F. Nichols
244 Wood Street
781.981.5436
tlarkin
Honored Contributor
This is correct, some of our Macbooks get switched into optical audio
mode and get stuck. I saw the toothpick thing on youtube and while it
does work, it is not 100%. Since the analog and optical output share
the same switch, when it gets stuck it disables all other audio.
