2 weeks ago
Hello!
My JAMF on prem server was set up before I arrived. We need to get packages to users who are working remotely, and able to receive them without being on our VPN. Is it possible to use a remote, cloud based, package distribution alongside, or mirrored to our on prem distribution point? I want it to be the fallback if on prem is not available. So far I haven't gotten this to work. Thank you !
2 weeks ago
What is stopping you from moving your current Distribution Point to a DMZ and making it publicly addressable? As far as using Jamf Cloud's Distribution Point specifically with on Prem Jamf, that is not possible.
2 weeks ago
@ngulick As @AJPinto already replied, using JCDS isn't itself possible to use as a DP, but you can use an AWS S3 bucket as Cloud based DP.
What's probably much easier, and what I used prior to switching to Jamf Cloud hosting which provides JCDS, is setting up an HTTPS server in your DMZ (don't ask to set up an Internet facing DP or your InfoSec team should instantly deny the request) that is synchronized with your on-prem DP.
2 weeks ago
Thanks very much for the replies, I guess we are going to attempt to use Jamf Sync to keep our on Prem package server and JCDS in sync. We run pretty heavy deployments, so I gather that was why the call was made to have the on premise be the primary package server. All good tips. Anyone have experience with Jamf Sync?
