Script for disabling ipv6 over ethernet
DaveB1
New Contributor II
Hello.
Does anybody have a  script that disables ipv6 over ethernet connections that works.
Thanks
D
1 ACCEPTED SOLUTION
sdagley
Esteemed Contributor III
@DaveB1 This script will do it for all active interfaces:
# Sets any network interface to IPv6 Link-Local Only mode
SAVEIFS=$IFS
IFS=$'\n'
interfaceList=($(networksetup -listallnetworkservices | grep -v -i -E "\*"))
interfaceCount=${#interfaceList[@]}
IFS=$SAVEIFS
for (( i = 0; i < interfaceCount; i++ ));
do
		echo "Working on interface ${interfaceList[$i]}"
		/usr/sbin/networksetup -setv6linklocal "${interfaceList[$i]}"
		/bin/sleep 1
done
6 REPLIES 6
sdagley
SAVEIFS=$IFS
IFS=$'\n'
IFS=$SAVEIFS
do
		/bin/sleep 1
done
AJPinto
Does this work on all interfaces or all active interfaces? I have also been poking at this myself for some time as a backlog thing and keep getting stuck on needing the network interface to be active and each dongle having its own interface.
sdagley
That will do all active interfaces (the filter for anything with an * excludes inactive interfaces)
DaveB1
New Contributor II
Thanks for your thoughts.
When I run the script in terminal directly on the mac. I get the below output and when I check the network settings ipv6 is still set to Automatically. I know I can change manually but I have 100+ macs to change this setting for so trying to avoid the personal touch.
Last login: Wed May  7 16:15:31 on ttys000
DaveB1 ~ %
DaveB1 ~ % SAVEIFS=$IFS
IFS=$'\n'
IFS=$SAVEIFS
do
    /bin/sleep 1
done
zsh: command not found:     echo
zsh: no such file or directory:     /usr/sbin/networksetup
zsh: no such file or directory:     /bin/sleep
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
sdagley
You can't simply paste the script into Terminal. Save it as a file named SetIPv6Mode.sh (use an editor like BBEdit) then in Terminal type the command "sudo " (include the space after sudo) then enter the path to the saved script file (dragging the the file from a. Finder window into the Terminal window sill do that for you) and hit return. When prompted for your password enter it (it won't echo the characters) and hit return.
Or just add the script to Jamf Pro and run it as a Script payload in Policy.
DaveB1
New Contributor II
You rock.
Thank you for your help.
