Posted on 02-01-2012 04:42 AM
Hi I want to create a smart group for Laptops and Desktops
These are the options listed
13-inch MacBook Pro (Early 2011) 13-inch MacBook Pro (Mid 2009) 13-inch MacBook Pro (Mid 2010) 15-inch MacBook Pro (Early 2011) 15-inch MacBook Pro (Mid 2009) 15-inch MacBook Pro (Mid 2010) 17-inch MacBook Pro (Early 2011) iMac Intel (Early 2008) iMac Intel (Late 2006) iMac Intel (Mid 2011) MacBook Pro (15-inch Core 2 Duo) MacBook Pro (Early 2008) MacBook Pro (Mid 2009) MacBook Pro (Mid/Late 2007) MacBookAir4,2 MacPro MacPro (Early 2008) MacPro (Early 2009) MacPro (Mid 2010) Power Macintosh G5 (Late 2005)
How do I assign all the MacPros to one smart group and all the MacBook Airs/Pros to another smart group
can I use the following condition?
MacBook Pro (15-inch Core 2 Duo),MacBook Pro (Early 2008) etc
Thanks
Solved! Go to Solution.
Posted on 02-01-2012 05:01 AM
I setup our Desktops Smart Group to look for items that did not contain "book" and our Notebooks SG to look for items that do contain "book". You can see screen caps here:
Desktops: http://cl.ly/3P38341F2q3u280Y0g3m
Notebooks: http://cl.ly/3I2Z0a360a2G3q3X1d0a
In the Desktops one, I have machines that are IT related with "Tech" in the name, hence the reason for that additional criteria in that screen cap.
Also, the Desktops one will grab everything that is not a MacBook computer.
HTH
Steve
HTH
Steve
Posted on 02-01-2012 05:16 AM
Excellent! exactly want I wanted
