Smart IPv6 Detection EA (Wi-Fi, Ethernet, VPN-aware) + Jamf Smart Group Ideas
Mcleveland
New Contributor III
Hey Mac Admins,
I wanted to share a custom Jamf Extension Attribute I wrote to help detect the current IPv6 configuration state for whichever network interface is actively routing traffic — including when a VPN tunnel is in use.
This script:
  • Detects the active interface via route get default
  • Handles VPN tunnel interfaces (utunX) by falling back to the actual enX interface from netstat -rn
  • Reports the hardware type (AirPort for Wi-Fi, Ethernet otherwise)
    • Categorizes the IPv6 mode as Automatic, Link-Local Only, or Off
      Example Result:
      <result>Ethernet - Automatic</result>
      Category  Group Name
      Network IPv6 Automatic – Ethernet Devices
      Network IPv6 Automatic – Wi-Fi Devices
      Network IPv6 Link-Local – Ethernet Devices
      Network IPv6 Link-Local – Wi-Fi Devices
      Network IPv6 Disabled – Ethernet Devices
      Network IPv6 Disabled – Wi-Fi Devices
      Network IPv6 Status Unknown – Needs Review
      Extension Attribute Script:
      # Jamf Extension Attribute: IPv6 State of Active Interface
      # Author        : Michael Cleveland, IT Engineer
      # Version       : 1.1
      # Last Updated  : May 1st 2025
      # Description   : Detects the active network interface (default route)
      #                 and evaluates its IPv6 configuration. Handles VPN
      #                 tunnels (utunX) by falling back to the real enX
      #                 interface using routing table data.
      # Output Format : <result>HardwareType - IPv6Status</result>
      #                 e.g., <result>Ethernet - Link-Local Only</result>
      # Changelog:
      #   1.0 - Initial release: IPv6 detection for active enX interface only
      #   1.1 - Added utun fallback logic to detect real interface during VPN usage
      plist="/Library/Preferences/SystemConfiguration/preferences.plist"
      result="Unknown"
      # ➤ Step 1: Identify the active network interface
      active_interface=$(route get default 2>/dev/null | awk '/interface: / { print $2 }')
      # ➤ VPN fallback: If interface is utunX, try to find enX interface from routing table
      if [[ "$active_interface" =~ ^utun[0-9]+$ ]]; then
          real_interface=$(netstat -rn | grep "^default" | grep -v utun | awk '{print $NF}' | head -n 1)
          if [[ -n "$real_interface" ]]; then
              echo "VPN interface '$active_interface' detected. Falling back to '$real_interface'."
              active_interface="$real_interface"
              echo "No fallback interface found for VPN default route."
              echo "<result>Unknown</result>"
      # ➤ Step 2: Parse all network services and find the matching interface
      service_ids=($(/usr/libexec/PlistBuddy -c "Print :NetworkServices" "$plist" 2>/dev/null | grep '^[ ]*[A-F0-9-]\{36\} =' | awk '{print $1}'))
      for sid in "${service_ids[@]}"; do
          device_name=$(/usr/libexec/PlistBuddy -c "Print :NetworkServices:$sid:Interface:DeviceName" "$plist" 2>/dev/null)
          if [[ "$device_name" == "$active_interface" ]]; then
              hardware_type=$(/usr/libexec/PlistBuddy -c "Print :NetworkServices:$sid:Interface:Hardware" "$plist" 2>/dev/null)
              config_method=$(/usr/libexec/PlistBuddy -c "Print :NetworkServices:$sid:IPv6:ConfigMethod" "$plist" 2>/dev/null)
              inactive_flag=$(/usr/libexec/PlistBuddy -c "Print :NetworkServices:$sid:IPv6:__INACTIVE__" "$plist" 2>/dev/null 2>&1)
              # ➤ Evaluate IPv6 status
              if [[ "$inactive_flag" == "1" || "$inactive_flag" == "true" ]]; then
                  ipv6_status="Off"
              elif [[ "$config_method" == "Automatic" ]]; then
                  ipv6_status="Automatic"
              elif [[ "$config_method" == "LinkLocal" ]]; then
                  ipv6_status="Link-Local Only"
                  ipv6_status="Unknown"
              result="$hardware_type - $ipv6_status"
              break
      done
      Let me know if you'd like the companion remediation script that automatically sets the detected interface to IPv6 Link-Local Only if it's still on Automatic. Hope this helps others managing IPv6-related quirks in VPN or security tooling.
      Thanks,
      Michael Cleveland
0 REPLIES 0
