NetBoot issues using 10.12.x nbi
  • January 20, 2017
  • 4 replies
  • 6 views
Since updating the nbi to 10.12.x I have been unable to NetBoot from different subsets. I'm also only able to NetBoot to up to around 7 devices at a time to Macs on the same subnet.
If I restore the 10.11 NBI it works fine.
I've tried multiple images using autodmg and creating a minimal base image. I've also tried tweaking the settings in autocaspernbi, but I keep getting the same result.
Is anyone else having similar issues with netbooting across subjects with 10.12.x?
  • 29 replies
  • January 23, 2017
I just created mine last week with 10.12.2 and it works fine with different subnets. When i have strange issues like that a reboot of our OSX server normally fixes it.
  • 75 replies
  • January 23, 2017
Thanks William, I'll test it again with 10.12.3 and see how it goes.
  • 75 replies
  • January 25, 2017
What version of the netsus appliance are you using to host the netboot images?
  • 29 replies
  • January 25, 2017
I dont use a appliance or i am to tired to understand the question, I use OSX server to host the netboot images.
