Hello everyone,
I downloaded the script below and uploaded to JAMF Pro. When I run sudo jamf policy, I get a message back saying parameters 4 is missing. I don't know what I need to put there. Does anyone know? Also, being that I'm running Mojave 10.14.5, do I need to make a change on the script?
!/bin/bash
Apple Software Update Search
Version: 2.0
Josh Harvey | Jul 2017
josh[at]macjeezy.com
Updated: Feb 2018
GitHub - github.com/therealmacjeezy
JamfNation - therealmacjeezy
####################### Change Log ########################
Version 2.0 Update (Feb 2018)
- Added support for multiple updates to used in the script parameters
(current limit is 4, version 1.0 only supported one item at a time)
- Rewrote the way updates are handled. Now any update that is found gets
added to an array then is downloaded to the default location (/Library/Updates/).
Once the update is finished downloading, it gets added to another array
which is then used to install each update after they all have been downloaded.
- Added a section that will check to see if the update requires a restart.
If it's required, it will set the "restartRequired" variable to yes. Once all
updates have been downloaded and installed, a if statement checks the restart
variable and will trigger a policy setup for an delayed authenticated reboot.
NOTE: A policy will have to be created with a matching trigger in order for this
feature to work. This section currently only looks for the "security" label.
- Added a manual inventory update before the restartRequired check to ensure
any installed updates are succesfully reflected in the Jamf Pro Server. (This
was written in to work around an issue where inventory updates would fail if
the update name exceeded a certain amount of characters.)
##################### USAGE / ISSUES ######################
Enter the item(s) you are trying to update in Parameters 4 through 7.
If you want an authenticated reboot to occur if required by an update
you will need to create a policy with a custom trigger (Set to Ongoing).
# If you have any issues or questions please feel free to contact
using the information in the header of this script.
If an item doesn't have any available updates, it will move onto the
next item (if entered). If no updates for any of the items are found
it will exit quietly.
Also, Please give me credit and let me know if you are going to use
this script. I would love to know how it works out and if you find
it helpful.
Script Parameters
Parameter 4 - Update Selection (Required)
Parameter 5 - Update Selection (Optional)
Parameter 6 - Update Selection (Optional)
Parameter 7 - Update Selection (Optional)
Parameter Options
iTunes - iTunes Update
macOS - macOS Software Update (Restart Required)
RDP - Remote Desktop Client Update
Security - Security Update (Restart Required)
App Store - Mac App Store Update (Restart Required)
Safari - Safari Update
formatInput() { # Arrays that contain multiple variations of each item to ensure it gets formatted correctly RemoteDesktop=("rdp" "RDP" "remote desktop" "remote" "Remote" "Remote Desktop") iTunes=("itunes" "Itunes" "iTunes") macOS=("macos" "MacOS" "MACOS" "osx" "OSX") appStore=("app" "appstore" "App Store" "App store" "Appstore") security=("Security" "security" "security update" "Security Update") safari=("safari" "Safari")
# Formats the item name
if [[ "${iTunes[@]}" =~ "$itemUpdate" ]]; then
itemUpdate="iTunes"
elif [[ "${macOS[@]}" =~ "$itemUpdate" ]]; then
itemUpdate="macOS"
elif [[ "${RemoteDesktop[@]}" =~ "$itemUpdate" ]]; then
itemUpdate="RemoteDesktop"
elif [[ "${appStore[@]}" =~ "$itemUpdate" ]]; then
itemUpdate="App Store"
elif [[ "${security[@]}" =~ "$itemUpdate" ]]; then
itemUpdate="Security"
elif [[ "${safari[@]}" =~ "$itemUpdate" ]]; then
itemUpdate="Safari"
Creates an empty array
updateList=()
Checks for input in each of the parameters and formats the string for use in the softwareupdate command
if [[ ! -z "$4" ]]; then
itemUpdate="$4"
formatInput
updateList+=($itemUpdate)
echo "Parameter 4 is missing and is required."
Parameter 5 (Optional)
if [[ ! -z "$5" ]]; then
itemUpdate="$5"
formatInput
echo "Parameter 5 is empty."
Parameter 6 (Optional)
if [[ ! -z "$6" ]]; then
itemUpdate="$6"
formatInput
echo "Parameter 6 is empty."
Parameter 7 (Optional)
if [[ ! -z "$7" ]]; then
itemUpdate="$7"
formatInput
echo "Parameter 7 is empty."
Sets the update count variable to zero then looks at the updateList array and checks to see if an update is available and if so downloads the update to /Library/Updates for each item
updateCount="0"
for i in "${updateList[@]}"; do
echo "Searching for an update for ${updateList[$updateCount]} .."
# Variable that searches for available software updates for the item
searchUpdate=$(/usr/sbin/softwareupdate -l | grep -w "" | sed 's/^[[:space:]]//' | grep -y "${updateList[$updateCount]}" | sed 's/[]//g' | sed 's/^[[:space:]]//')
# Checks to see if there is an update available, if not it will return No Update Found and continue to the next item
if [[ -z "$searchUpdate" ]]; then
echo "No update found for ${updateList[$updateCount]} .."
echo "Update found for ${updateList[$updateCount]} .. Starting download."
installList+=("$searchUpdate")
/usr/sbin/softwareupdate -d "$searchUpdate"
echo "Download of "${updateList[$updateCount]}" finished"
let updateCount+=1
done
Sets the install count variable to zero then looks at the installList array and runs the softwareupdate command with the install flag for each item in the array
installCount="0"
for i in "${installList[@]}"; do
echo "Installing the update for "${installList[$installCount]}" ..."
/usr/sbin/softwareupdate -i "${installList[$installCount]}"
echo "Installation of "${installList[$installCount]}" is complete."
let installCount+=1
done
Updates the inventory to reflect the installed updates
sudo /usr/local/bin/jamf recon
Lists the updates that were installed
echo "The following updates have been installed:"
echo "${installList[@]}"
Checks to see if a restart is required
if [[ "${installList[@]}" =~ Security ]]; then
echo "A restart is required for this update"
restartRequired="yes"
restartRequired="no"
Checks the restart variable to see if a restart is required and if so runs the trigger for a policy set to perform an authenticated restart
if [[ "$restartRequired" == "yes" ]]; then
echo "Restart is Required"
# Edit the line below to match the policy in the Jamf Pro server
sudo /usr/local/bin/jamf policy -event securityReboot
echo "No Restart Required"
