I just modified the script I used for lease data updates to update the asset tag of a mobile device and tested with a device in my JSS. This worked to update the asset tag with the data I specified in the CSV file. The CSV file had only the serial number in the first column and the asset tag info in the second column with no headers at all.
# Name: updateAssetTags.sh
# Date: 17 June 2015
# Author: Steve Wood (swood@integer.com)
# Purpose: used to read in asset tag data from a CSV file and update the record in the JSS
# This script is written for updating a mobile device in the JSS but can be altered for a computer
# by simply changing the <mobile_device> and </mobile_device> tags to <computer> and </computer>
# The CSV file needs to be saved as a UNIX file with LF, not CR
# Version: 1.0
# A good portion of this script is re-purposed from the script posted in the following JAMF Nation article:
# https://jamfnation.jamfsoftware.com/discussion.html?id=13118#respond
jssAPIUsername="<apiuser>"
jssAPIPassword="<apipassword>"
jssAddress="https://your.jss.com:8443"
file="<path-to-csv-file>"
#Verify we can read the file
data=`cat $file`
if [[ "$data" == "" ]]; then
echo "Unable to read the file path specified"
echo "Ensure there are no spaces and that the path is correct"
exit 1
#Find how many computers to import
computerqty=`awk -F, 'END {printf "%s
", NR}' $file`
echo "Computerqty= " $computerqty
#Set a counter for the loop
counter="0"
duplicates=[]
id=$((id+1))
#Loop through the CSV and submit data to the API
while [ $counter -lt $computerqty ]
do
counter=$[$counter+1]
line=`echo "$data" | head -n $counter | tail -n 1`
serialNumber=`echo "$line" | awk -F , '{print $1}'`
assetTag=`echo "$line" | awk -F , '{print $2}'`
echo "Attempting to update lease data for $serialNumber"
echo $serialNumber " " $myID " " $assetTag
apiData="<mobile_device><general><asset_tag>$assetTag</asset_tag></general></mobile_device>"
output=`curl -sS -k -i -u ${jssAPIUsername}:${jssAPIPassword} -X PUT -H "Content-Type: text/xml" -d "<?xml version="1.0" encoding="ISO-8859-1"?>$apiData" ${jssAddress}/JSSResource/mobiledevices/serialnumber/$serialNumber`
#Error Checking
error=""
error=`echo $output | grep "Conflict"`
if [[ $error != "" ]]; then
duplicates+=($serialnumber)
#Increment the ID variable for the next user
id=$((id+1))
done
echo "The following mobile devices could not be updated:"
printf -- '%s
' "${duplicates[@]}"
I also posted this to my GitHub: UpdateAssetTags
Test this out before using wide spread. The script needs to be modified to include your API user/pass, your JSS URL, and the path to the CSV file. The next version of this needs to be able to take the CSV file as an argument on the command line.
Good luck!
