Product Enhancements
Jamf Connect Configuration 1.1.0: MFA Testing for Okta
You can now use the Okta Test window to test multi-factor authentication (MFA), if enabled in the Okta dashboard. When enabled, the Okta Test window will prompt you to select from Okta-enabled MFA options, and then complete the MFA prompt from the Okta Test window.
To learn more about using MFA with Okta, see the following Okta documentation: https://help.okta.com/en/prod/Content/Topics/Security/MFA.htm
Jamf Connect Login 1.5.0: Azure AD Hybrid Identity Support
Jamf Connect now supports authentication with environments that use both Azure AD and on-premise Active Directory. Jamf Connect can be configured to authenticate users with Azure AD, and then sync a local account password with their on-premise AD password. Jamf Connect can be configured to support the following Azure authentication methods:
• Password harsh synchronization
• Pass-through authentication
• Federated integration (AD FS)
For more information about configuring Jamf Connect with an Azure hybrid identity environment, see the following Knowledge Base articles:
• Configuring Jamf Connect with Azure AD Hybrid Identity Solutions
• Understanding Jamf Connect Authentication with Azure AD Hybrid Identity Solutions
User Prompting Improvements
Users are now prompted to log in with their network account, if they attempt to log in locally but are not allowed because the DenyLocal key is set true and the user is not specified in the DenyLocalExcluded key.
Jamf Connect Sync 1.0.7: UI Improvements
The following UI changes were made to the Preferences menu:
• Added placeholder text with example values
• Changed some preference setting labels to match between Jamf Connect Sync and Jamf Connect Configuration’s Sync pane
Bug Fixes
Jamf Connect Configuration 1.1.0: [JC-632] Fixed an issue that caused Jamf Connect Configuration to quit unexpectedly when the Reset button was pressed twice in a row.
• [PI-007051] Fixed an issue that prevented the keychain item for Jamf Connect Login from being updated after the Okta password change.
• [PI-007355] Fixed an issue that caused new local accounts based on an Azure AD username formatted as first.last@example.com to create the local account username as “First FirstLast.”
Jamf Connect Verify 1.1.4: N/A
Product Documentation
For more information, including Release Notes, please see the Jamf Connect Administrator Guide
