Teamviewer intergration - self service notifications not working
  • September 14, 2021
  • 24 replies
  • 79 views
Hi All,
I have set up to integrate our Teamviewer and Jamf but when i start a session and click on "Send Self Service Notification", nothing comes up on the mac. We have enabled self service notifications so i am not sure what is wrong but if i manually open up self service then i see the link for teamviewer.
Any ideas?
Regards,
Ameetraj
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • 1913 replies
In addition to enabling notifications for Self Service, verify two other things:
  1. In Jamf Pro under Settings > Global Management > Push Certificates, you need to have a Push Proxy certificate in addition to your MDM Push Notification Certificate.
  2. Under Settings > Computer Management > Security, you need to enable the Notifications profile for Jamf management framework and Self Service.
  • 22 replies
I have all those set and it works when i use the user interaction tab in policies. So not sure what is wrong here, only not working for teamviewer.
  • 145 replies
  • September 17, 2021
Same behavior.
Did you find a solution ?
Thank you
  • 22 replies
Same behavior.
Thank you
Unfortunately no, i tried on few of my mac devices and they all are behaving the same.
  • 145 replies
I just deleted and re-created the Push Proxy Settings certificate but still the same problem. Self We have tried on 10.15, 11.x and 12 beta 6 without success.
I tried to uncheck "Jamf management framework and Self Service" in Settings -> Computer Management Framework -> Security then wait 30mn and check the option again but without success.
However, I can see the self service in the list of applications in the notifications center and everything seems correct.
I also tried adding "com.jamfsoftware.selfservice.mac" and "com.jamfsoftware.Management-Action" in the Notifications payload of a configuration profile but still not ...
  • 22 replies
  • September 21, 2021
Did you get anywhere with this? I am still not getting the notification.
  • 145 replies
Still not, I opened a support ticket.
I'll let you know if we can solve the problem
  • 45 replies
  • September 24, 2021
I've just configured this integration and I'm having the same issue.
I also connected my MacBook to my phone as hotspot to rule out our network. I think the problem is either with Jamf itself or Sophos Endpoint.
  • 22 replies
what makes you think it is sophos endpoint? We are also using it and it would be interesting to know that it is Sophos as it was causing us some other issues recently. I will test by removing Sophos.
  • 831 replies
  • October 1, 2021
I don't use sophos and we still are not getting the notifications on Teamviewer.
  • 26 replies
  • October 25, 2021
I'm also seeing the same issue here. No Sophos or other 3rd party security software here either.
  • 145 replies
  • October 28, 2021
Since Jamf 10.33, we still have the problem of notifications that are not displayed but in addition, when we try to trigger a remote session via the JSS, we click on "Start session" in the workstation inventory and we have the message: "End user is offline" while the computers are reachable (Check-in and inventory OK).
  • 45 replies
  • October 29, 2021
Hi @asidhu,
That's the only thing that could be blocking my connections. But apparently there's nothing to do with it.
  • 45 replies
  • October 29, 2021
Hi @glpi-ios,
The End user is online will show after the end user starts the TeamViewer session by using the provided link.
At the moment, the user is not being notified by Self Service but if you tell them to access that particular link it should work. Then you as the remote person can click on the link available as the admin user and connect to it.
  • 145 replies
  • October 29, 2021
Hi @luispalumbo
Indeed you are right, it works well, you just have to warn the user to go to their Self Service / Bookmarks.
So the only remaining problem is about notifications.
Thank you for your help
  • 9 replies
  • November 4, 2021
Currently running into this issue.  Has anyone found a work around?
lukasz_slodziak
  • Employee
  • 140 replies
  • November 17, 2021
Hey! I just wanted to join the conversation to thank you for all the reports of inconsistent, or in some cases, completely ineffective notification delivery. We will be investigating the issue, but I'd like to encourage you to continue reporting and providing additional feedback that can provide more context.
Some reports said that pressing the Resend Self Service notification button forces the notification to appear on the end user machine. This results in two notifications, which is still incorrect, but at least the notification reaches the user. Has that also been your experience?
Thank you again for your your feedback!
  • 145 replies
  • November 17, 2021
@lukasz_slodziak pressing the Resend Self Service notification button doesn't work for me 😞
  • 26 replies
  • November 24, 2021
Resending doesn't do the trick for me either.
  • 28 replies
  • December 2, 2021
Hi all,
I saw this issue 2 month ago that some notifications via Patch Management or like here for TV is not displayed to the enduser.
My ticket is closed based on the PI-010131 that was opened for this. Perhaps you can verify the problem and use the PI as a reference.
  • January 26, 2022
Still experiencing this issue and resending notification isn't working either.  Has anyone made any more headway on this?
  • 28 replies
  • January 26, 2022
I checked last week the PI with the Success-Team. They said that the PI was resolved. So I double checked this and replied that this issue still exist. So the PI is open again. Perhaps it make sense to open a case and point to the PI-010131.
  • 22 replies
  • January 27, 2022
Since i created this thread, tested few times then just gave up and since then never bothered to look into it. I will check if its still the same and update you guys :)
  • August 9, 2022
Anyone find a fix for this. Every time i click on the link it takes me to the TeamViewer webpage to download the client then it keeps doing the same thing
