Hello Jamf Nation!
I'm trying to create a configuration profile for our Office WiFi network. I have already referred to Jamf's documentation about creating a config profile for a network and that seemed to work when I tested it. Our office network doesn't need any certs or authentication to join and only needs the WiFi password to join, so no extra requirements there.
However, one thing I tried while testing the configuration profile was to remove the WiFi network from the Mac's system preferences and see if the configuration profile would automatically redeploy and reconnect to the Office WiFi like it did initially. That did not happen. I am under the assumption that if for whatever reason the WiFi network were to be removed from a user's system preferences, the config profile will just sit there until it is removed and re-added in Jamf Pro. Since we are in a hybrid work environment, we do not want to go the route of blocking access to system preferences, and it might be a little tough having to manually search to see if all of our computers actually have the WiFi network saved. We were also thinking of having this run as an event every login, but our users seldom reboot or logoff so it might not help us out there. (old habits never die)
My question then is; before having to go the route of just packaging this and tossing it in Self Service, is there any way that we can have this run automatically to make sure that if the Office WiFi were to ever be removed for whatever reason, it will redeploy itself per the config profile?
Thank you for your time!
-Frank S.
