Jamf Pro Server actions privileges
  • August 4, 2023
  • 26 views
BCPeteo
There are a bunch of privileges settings under server actions in group privileges that I can not find any documentation on exactly what they do. Does any one know or can you point to me to where this is documented?
The privileges are:
Send Local Admin Password Command
Send MDM Check In Command
Send Set Recovery Lock Command
View License Serial Numbers
View Local Admin Password
View Local Admin Password Audit History
View Recovery Lock
Allow User to Enroll
Send Application Attributes Command
Send Computer Unlock User Account Command
1 reply
BCPeteo
  • 152 replies
  • August 4, 2023
I did find that
• Send Local Admin Password Command
• Update Local Admin Password Settings
• View Local Admin Password
• View Local Admin Password Audit History
Are all part of the new Jamf Laps feature
