MUT alternative ?
  • May 15, 2025
  • 32 views
  • 8 replies
Hello,
Since MUT no longer works with a JSS instance using SSO authentication, do you know of any alternatives, please?
I admit I'm a bit uncomfortable with API scripts.
I need to create a static group with more than 500 devices 😁
thank you
Best answer by sdagley
@RaniPM You should still be able to use MUT with SSO authentication as the API calls it uses don't engage the SSO authentication path.
sdagley
  • 3567 replies
  • May 15, 2025
  • 8 replies
  • May 15, 2025
Thank you @sdagley  for your response. I'm sorry, I was convinced that I had already tried this a few weeks ago without success, and I had seen comments from other people having the same issue as me with SSO authentication.
But I confirm that it works well with a local JSS account.
Thank you, and sorry.
  • 12 replies
  • June 14, 2025
the new version of Jamf Pro is deprecated and allows Basic Authentication for the Classic API
