Checksum of the jamf agent did not match. Upgrading jamfHelper.app... Loop (8.6.1)
  • August 22, 2013
  • 13 views
bentoms
Forum|alt.badge.img+35
One of my managed clients (a 10.8.4 server DP), is submitting malformed inventory..
Basically inventory is failing & it has a Recon date of 11/30/0002 at 12:00 AM in the JSS!
I have re-repaired permissions, verified the disk.. Removed the mac from the JSS.. Removed the framework.. Made sure that DNS is correct & flushed the cache on the client.. Removed all JAMF keychain items & yet we still keep getting errors like the below:
Thu Aug 22 16:44:34 SK-MAC-JSS-01 jamf[821]: Upgrading jamf agent... Thu Aug 22 16:44:54 SK-MAC-JSS-01 jamf[821]: Checksum of the jamf agent did not match. (md5: /private/tmp/jamfAgent: No such file or directory != 209ae2ad3b15f99cd63ac5c0c1f9470d) Thu Aug 22 16:44:54 SK-MAC-JSS-01 jamf[821]: Upgrading jamfHelper.app... Thu Aug 22 16:45:15 SK-MAC-JSS-01 jamf[821]: Checksum of the jamfHelper did not match. (md5: /private/tmp/jamfHelper.app/Contents/MacOS/jamfHelper: No such file or directory!=d3d9721ff246acac29f7d3f37e28b08c) Thu Aug 22 16:45:15 SK-MAC-JSS-01 jamf[821]: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.checkForTasks.plist... Thu Aug 22 16:45:15 SK-MAC-JSS-01 jamf[821]: Adding launchd task com.jamfsoftware.task.checkForTasks... Thu Aug 22 16:45:56 SK-MAC-JSS-01 jamf[935]: Enforcing management framework... Thu Aug 22 16:45:56 SK-MAC-JSS-01 jamf[935]: Enforcing scheduled tasks... Thu Aug 22 16:45:56 SK-MAC-JSS-01 jamf[935]: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.1.plist... Thu Aug 22 16:45:57 SK-MAC-JSS-01 jamf[935]: Adding launchd task com.jamfsoftware.task.1... Thu Aug 22 16:45:58 SK-MAC-JSS-01 jamf[935]: Creating launch daemon... Thu Aug 22 16:45:58 SK-MAC-JSS-01 jamf[935]: Creating launch agent... Thu Aug 22 16:45:58 SK-MAC-JSS-01 jamf[935]: Downloading the agent... Thu Aug 22 16:45:58 SK-MAC-JSS-01 jamf[958]: Checking for policies triggered by "downloadJAMFAgent"... The management framework will be enforced as soon as all policies are done executing. Thu Aug 22 16:46:39 SK-MAC-JSS-01 jamf[958]: Upgrading jamf agent... Thu Aug 22 16:46:59 SK-MAC-JSS-01 jamf[958]: Checksum of the jamf agent did not match. (md5: /private/tmp/jamfAgent: No such file or directory != 209ae2ad3b15f99cd63ac5c0c1f9470d) Thu Aug 22 16:47:00 SK-MAC-JSS-01 jamf[958]: Upgrading jamfHelper.app... Thu Aug 22 16:47:20 SK-MAC-JSS-01 jamf[958]: Checksum of the jamfHelper did not match. (md5: /private/tmp/jamfHelper.app/Contents/MacOS/jamfHelper: No such file or directory!=d3d9721ff246acac29f7d3f37e28b08c) Thu Aug 22 16:47:20 SK-MAC-JSS-01 jamf[958]: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.checkForTasks.plist... Thu Aug 22 16:47:20 SK-MAC-JSS-01 jamf[958]: Adding launchd task com.jamfsoftware.task.checkForTasks... Thu Aug 22 16:47:59 SK-MAC-JSS-01 jamf[1075]: Enforcing management framework... Thu Aug 22 16:47:59 SK-MAC-JSS-01 jamf[1075]: Enforcing scheduled tasks... Thu Aug 22 16:47:59 SK-MAC-JSS-01 jamf[1075]: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.1.plist... Thu Aug 22 16:47:59 SK-MAC-JSS-01 jamf[1075]: Adding launchd task com.jamfsoftware.task.1... Thu Aug 22 16:48:01 SK-MAC-JSS-01 jamf[1075]: Creating launch daemon... Thu Aug 22 16:48:01 SK-MAC-JSS-01 jamf[1075]: Creating launch agent... Thu Aug 22 16:48:01 SK-MAC-JSS-01 jamf[1075]: Downloading the agent... Thu Aug 22 16:48:01 SK-MAC-JSS-01 jamf[1091]: Checking for policies triggered by "downloadJAMFAgent"... The management framework will be enforced as soon as all policies are done executing. Thu Aug 22 16:48:39 SK-MAC-JSS-01 jamf[1091]: Upgrading jamf agent...
Best answer by bentoms
With the assistance of the forever helpful Drew@JAMF & my NW team we isolated this due to a network issue on the site that was only affecting the server due to a WINS setting.
Odd. But A-OK now.
bentoms
  • 4331 replies
  • August 22, 2013
oh & there are 12 clients on the same VLAN as the DP all working fine..
when running sudo jamf enroll -prompt i get the following after entering my credentials:
Downloading the JSS CA Certificate... There were (1) previous JAMF device identities found on this computer. Removing... This computer was successfully enrolled to the JSS with the following device certificate: "B38BCEFF-F164-5A89-832E-D699E13C72CB" Failed to submit inventory Getting management framework from the JSS... Enforcing management framework... Checking availability of https://jss.company.com:8443/... The JSS is available. Enforcing login/logout hooks... Enforcing scheduled tasks... Creating launch daemon... Creating launch agent...
bentoms
  • 4331 replies
  • August 23, 2013
Odd. But A-OK now.
