Client ID on PreStage Enrollment Not Taking
rickwhois
Contributor
I'm trying to get the $SERIALNUMBER to be the computer name of Macs that are joined to AD in a DEP PreStage Enrollment. $SERIALNUMBER doesn't seems to work it keeps defaulting to Macbook Air or whatever the device type is. 5c2ee8cebbe04d7a9da08287a3d340eb
This device has been in JSS prior to re-enrollment. Any clues as to where I should be digging?
1 REPLY 1
rickwhois
Contributor
Just following up here... so it does bind as the serial number, but doesn't change the host name on the client. I suppose I could just add a script post DEP to update the hostname/host/computername.
Can anyone confirm this is normal behavior?
