Jamf Pro 10.3 Maintenance Release Coming Soon
  • April 3, 2018
  • 33 replies
  • 307 views
We have identified an issue when using current and previous versions of Jamf Pro to upgrade devices to iOS 11.3. As a part of the MDM Software Update workflow, Jamf Pro will monitor the status of that update. Devices upgraded to iOS 11.3 are returning a new response that does not match Apple’s documented protocol. This response will cause the device to remain in a failed loop, which prevents it from receiving further commands.
We are working on a maintenance update for Jamf Pro 10.3 that will handle the new response from iOS 11.3 devices and prevent this failure. We recommend that organizations avoid using the MDM Software Update workflow to upgrade devices to iOS 11.3 until this maintenance release is available.
Any devices that did go through this MDM Software Update workflow should have their MDM communication restored after upgrading to this maintenance release of Jamf Pro 10.3.
This release will be available in the coming days to all on-premises and cloud customers. We will communicate in a future email when you can download the installers on Jamf Nation. The cloud upgrade, still scheduled for April 14th, will receive this maintenance release as well.
Please reach out to your account representative if you have any questions.
  • April 3, 2018
@michael.devins Thanks for your quick response.
I have to advocate for a 9.101.x release as well though. As far as I know Jamf never announced end of support for version 9. This is a severe enough bug I think it warrants a new release. We have no plans to update to Jamf Pro 10 until this summer. As it stands that would mean we don't get access to this fix. Upon release 9.101 was promised as having support for iOS 11 and macOS 10.13.
  • April 3, 2018
@michael.devins I want to clarify what “the MDM Software Update workflow” is. I suspect it is where I would send an iOS update command out to devices from the server side. I wish for a confirmation though such a workflow is the only one affected.
@blackholemac The MDM Software Update workflow I'm referring to is using the Jamf Pro action to "Send Remote Commands" and select "Update iOS Version..."
  • April 4, 2018
We are on the same page.
  • April 4, 2018
Will this Maintenance release also address the issues with Jamf Imaging and Enrollment Invitation errors?
  • April 4, 2018
I would also like to see a patch for version 9 of Jamf Pro.
  • April 4, 2018
@michael.devins Where in the JSS is this "Update iOS Version" command that you speak of? I don't see it.
  • April 4, 2018
Not sold that v10 is a good fit for us at this time. I would also advocate for v9.101.x fix. Thank you.
@sedwards From a selection of Mobile Devices, select Action in the lower right, Send Remote Commands. On the top of the next page is "
Update iOS Version on supervised devices." This will send an MDM command to update iOS based upon your selection and iOS Update Action.
  • April 4, 2018
We are seeing far more issues than ios update commands after upgrading to 10.3. Our Self Service web clip no longer functions on iOS. Update Inventory commands backup the queue's on the device, etc. None of our devices are on 11.3, they are all 11.2.5.
nvandam
  • April 4, 2018
Does it matter if I chose "Download the update for users to install" or "Download and install the update, and restart devices after installation"?
I would also advocate for a 9.101 patch. At the very least give us 9.101 folks the option to go through the support channels to get a patch and or a database tweak.
  • April 4, 2018
I have to say that Jamf Pro 10+ has been a disaster so far. Right now, we can't image machine. We can't create QuickAdd packages in Recon. And the admin console is just so incredibly slow and frustrating to work with. It doesn't seem that the functionality hasn't changed at all -- JAMF just wanted to make it 'prettier.' I wish we could roll back to 9.101. With Apple breaking everything left-and-right with the release of 10.13.4, and Jamf Pro 10.3 removing the simplest of functionality, I'm going to need serious migraine medication.
  • April 5, 2018
Does it affect those of us on hosted Jamf 10.2.2? Or those users who update on their own?
bpavlov
  • April 5, 2018
@michael.devins Some people on Slack have mentioned they did not get an email about it. I personally got an email about it though. I was wondering how it was determined who would receive emails or not. Good job on communicating this quickly by the way.
  • April 5, 2018
@smunroe I've been 10.2.1 for weeks without imaging issues and can create quickadds and use the admin console ok. I'd nicely suggest testing releases in a test environment if you don't already to try to minimize the upgrade pain (and try not to wait too long between releases if you can, it makes them easier to swallow and test in my experience). I also wouldn't upgrade to new release (not sure you did, just general info) the day or even week it comes out if you can help it. Though it seems like lots of people may be jumping to latest release when this MR comes out.
@jl789work The affected workflow is using MDM commands to upgrade devices to iOS 11.3, regardless of Jamf Pro version. End users who upgrade on their own are not impacted.
@bpavlov We sent the email to all current Jamf Pro customers, though that group appears to have missed some MSP and Integrator partners. We posted the same message to Jamf Nation in tandem to ensure full transparency with our communication.
  • April 5, 2018
the picking and choosing of which questions/comments to respond to on this thread is interesting to see. there are several people asking about a possible patch for 9.101 that are being blatantly ignored. i'm at 10.1.1something so not personally affected - i just think it is curious...
  • April 6, 2018
@michael.devins will there be a 9.101.x update? i did push an update to an ipad to 11.3, and it did display symptoms of the issue that was reported...
using 9.101.4
  • April 6, 2018
Is there any chance of this being released today, or this weekend? We've got PARCC testing on Monday, and right now this issue has us a bit handcuffed, as our effected student devices cant receive commands from Self Service.
Either way, your hard work is greatly appreciated. Thanks!
Forum|alt.badge.img+15
  • April 6, 2018
@kmeyer Contact your account manager or support. There are options.
donmontalvo
Forum|alt.badge.img+36
  • April 6, 2018
We've been told Jamf Pro 9.101.x will not receive any more development, although we might see a patch if a show stopper is found.
The writing is on the wall on getting to Jamf Pro 10.x, not just for compatibility/feature support, but so Jamf doens't get strung so thin that they have to split resources between two different sets of code. That would affect the quality of both versions IMHO.
We are not the cutting-edge-gotta-keep-up-with-the-Jones'-gun-slingers type, so we try hard to avoid jumping into the scream-test rabbit hole. But in this case we're doing everything we can to get to Jamf Pro 10.x, because it makes so much sense.
With all Apple's recent missteps...KEXT management...FileVault2/APFS/secureToken madness...etc...we can't afford to get caught with our pants down, being on Jamf Pro 9.101.x.
We tested Jamf Pro 9.101.4 > 10.3 and despite our having Jamf Pro clustered, load balanced (internal and DMZ), MySQL replicatino/failover, tons of API development going to/from Jamf Pro, and a bunch of complex deployment workflows, the upgrade process was refreshingly smooth.
Don
  • April 6, 2018
@donmontalvo Good to hear you had a positive experience. Writing's on the wall we will most likely be forced to version 10 as well.
Have to ask though, is breaking MDM communication with iOS not a show stopper? Depending on your scale that could mean hundreds of work hours to fix.
  • April 6, 2018
