Jamf Pro; Upgrade methods for Mojave.
  • Sep 2, 2018 12:22 PM UTC
  • 110 replies
  • 1156 views
ThijsX
Forum|alt.badge.img+20
Hi All,
Lets share idea's about how to upgrade to macOS Mojave via;
  • Self Service
  • App Store
  • Others
Also an idea to share idea's an how to upgrade from 10.14.1 to 10.14.2 due the new Software Update pane in Sysprefs.
Cheers.
  • Sep 12, 2018 7:13 PM UTC
Also interested in seeing if anyone has any upgrade or imaging solutions, we've tried a few things at our test environment but haven't had any luck yet with it.
  • Sep 12, 2018 7:28 PM UTC
We fully integrated DEP for new computer deployment.
I'm hoping for this workflow to work for upgrade: https://github.com/kc9wwh/macOSUpgrade
  • Sep 12, 2018 8:03 PM UTC
This is how we did it with High Sierra upgrade and will repeat for Mojave, its sounds hard but its very simple.
We put a Restricted Software policy to block updater from Apple and delete. The reason for this is Apple will start putting an Updater on the Mac and if you wait until .1 or .2 (10.14.1 etc) you will want the new installer from Apple App Store.
We then created a Self Service category called High Sierra Update.
In it we created a 01 High Sierra Pre-requisites self service item. This was a policy with a bunch of .pkgs we want to update before installing High Sierra. We also used Execute command to write a receipt on completion called hsready.pkg and we also do a recon and force a reboot.
We created a smart group with a criteria for the receipt hsready.pkg. Macs that has run 01 High Sierra Pre-requisites get added to the smart group. The Restricted software policy had this smart group as an exclusion. So once 01 High Sierra Pre-requisites the Mac can now run the HS updater.
We created a 02 Install High Sierra self service item, and scope the same smart group. This item is just a link to the apple App store to down the latest version of the High Sierra installer. User gets the file direct from Apple.
After the Mac reboots user goes back to self service and 02 Install High Sierra in now available to them and they can download and install.
Easy :)
ThijsX
  • Employee
  • Sep 12, 2018 8:40 PM UTC
Awesome idea’s. We succesfully tested the method developed by @bpavlov with recent Mojave beta.
link text
ImAMacGuy
Forum|alt.badge.img+23
  • Sep 13, 2018 12:28 PM UTC
@txhaflaire we use @bpavlov 's solution as well and have been checking back periodically to his site for updates to his script, were there any changes you had to do or was it pretty much update the build #s and policies for the new OS?
bpavlov
  • Sep 13, 2018 2:10 PM UTC
Sorry guys. I've been quite busy on other things. I'll try to take a look at the script again and make whatever necessary changes are needed for 10.14.
  • Oct 11, 2018 7:07 PM UTC
Does anyone know if the github macOSUpgrade script works with Mojave yet? I tried it today and it appeared to have an issue with the download step -- it looks like the Install MacOS Mojave.app phones home to the Apple servers to get the install, and is only 22 MB versus the average 5 GB installers from Sierra/High Sierra. Doing it for High Sierra works fine.
We're not in a rush to deploy Mojave yet (we still have a few hurdles we need to address) but we wanted to at least start testing as we anticipate demand.
  • Oct 11, 2018 7:25 PM UTC
@spreston I had the same issue at first, but I'm not sure why or how I got the tiny stub installer rather than the full 5GB+ installer. Apple does still give you the full installer. Try deleting it from /Applications and downloading again from the App Store. I suspect I might have got the small stub because I was still enrolled in the beta/developer program. I have not tested this by re-enrolling, so all I can say is it worked the first time I re-downloaded after un-enrolling my computer from the beta.
I'm not using that specific script, but I can tell you that the process is not much different than in High Sierra. The only difference I noticed is that startosinstall now complains if you specify --applicationpath (it is deprecated; and about time, too, since it was always redundant).
  • Oct 11, 2018 7:29 PM UTC
@mjhersh - that was definitely it. Just did a re-download and it's 6 GB now. I'll re-package and try again. Thanks!!
  • Oct 11, 2018 7:50 PM UTC
Just to add...
To get around the stub installer (in my experience) if you manage to keep a computer around running something pre-Mojave, open the Mac App Store and alt-click the download (or install/get) button on the macOS Mojave app page and it will always download the full version. I'm not sure if this is officially documented anywhere, but it seems to work for me consistently, and avoids you having to download multiple times. The alt-click feature does not seem to work in the new Mac App Store, but I haven't checked this again since one of the more recent betas.
  • Nov 6, 2018 11:29 PM UTC
I can't get our test machine to update to macOS Mojave!
We have 2 policies that download and install macOS Mojave.
  • I packaged up the Mojave 6GB installer, and the first policy that places the installer in the root /Applications folder.
  • Then a 2nd Policy runs the macOSupgrade.sh script with the parameters defined.
After the policy runs, I get the "Wait as we prepare your computer for mojave" screen. Looks like everything is going well until I get a prompt "osinstallersetupd wants to make changes" which requires the user to input a Admin password, which they do not have.
Is it something in my Install Policy's reboot settings? Some parameter I misdefined? Or is it the lack of a custom trigger? HELP!!
  • Nov 7, 2018 7:55 PM UTC
Yeah, I have the full installer copying down to /Applications, but when MacOSUpgrade.sh runs, it deletes it, then tries to download it via the custom trigger(which works if I call it manually from the command line), but then falls over dead saying it couldn't download successfully. Derp.
I managed to get our test computer to install Mojave with the "Erase Install" script for post-10.13.4 machines, from a High Sierra machine through Self Service.
Obviously it completely images the computer so if you're only after an upgrade it won't work.
  • Nov 8, 2018 3:48 PM UTC
@Caleb.Anderson Also the eraseinstall flags only work on APFS formatted drives. Still, it has some use as an alternative for reimages.
alexkaloostian
I am also having problems with startosinstall, it keeps asking for admin privileges. I get the osinstallsetupd prompt. Jamf logs says "Could not create a preboot volume for APFS install."
Forum|alt.badge.img+15
  • Nov 8, 2018 5:31 PM UTC
Tagging for updates.
MLBZ521
  • Nov 8, 2018 6:41 PM UTC
There are several projects out there to perform upgrades and 'erase installs.' I haven't looked at some of the scripted methods since I created my own for my environment. Mine has been updated for Mojave In case anyone is still looking for one:
install_macOS
If setup properly, it will not prompt for credentials.
  • Nov 8, 2018 9:07 PM UTC
If you all need full installers please use installinstallmacos.py.It works every time.
  • Nov 8, 2018 9:26 PM UTC
What are folks doing to get custom privacy preferences config profiles on the machine as soon as possible?
It appears that they wont install until recon is run and sees the machine is 10.14, since you cannot deploy to pre 10.14 machines ahead of time. I was thinking a script that ran "ongoing" that would be scoped off a dummy package. In the script, if the OS level was pre 10.14 the script would exit, but if it saw 10.14, it would delete the dummy receipt, run a recon and get the config profiles as a result.
Anybody have a better way?
  • Nov 8, 2018 10:24 PM UTC
@ocla&&09 Assuming that you're using the generic Self Service method, would it be possible to add a maintenance payload {update inventory} to your policy to run after the upgrade is complete? I guess you could also have an update inventory policy that runs at startup assuming that you already have a 10.14 smart group scoped for your profiles...I'm just trying to keep it simple.
  • Nov 9, 2018 11:12 AM UTC
@spreston
How did you solve the download issue for Mojave
I followed this one https://github.com/kc9wwh/macOSUpgrade
Everytime it just comes up that it could not be downloaded
  • Nov 9, 2018 2:00 PM UTC
@jameson - is the Mojave installer ~5-6 GB? If not you may need to download/re-package again.
Other issue we encountered was if the drive was in the process of encrypting it would fail. (I initially missed that in the readme notes).
  • Nov 9, 2018 2:05 PM UTC
@jameson it sounds like you're using a stub installer. Use installinstallmacos.py to download full installers every time.
  • Nov 9, 2018 2:06 PM UTC
Thanks @woodsb - didn't know about this!
  • Nov 10, 2018 2:47 AM UTC
I created a support case for this issue. Here's the response I received from Tyler of the jamf support team in regards to the osinstallersetupd prompt:
"So what is happening is if the user is standard and have FIleVault 2 enabled it will require an admins password. In one discussion in Jamf Nation someone has modified the script that checks to see if the user is standard and has FileVault 2 enabled and if it does it will promote the user to Admin. Once the installation completes it uses a LaunchDaemon to demote the user back to standard. [...]"
Here's the modified macOSUpgrade script:
# Copyright (c) 2018 Jamf.  All rights reserved.
#       Redistribution and use in source and binary forms, with or without
#       modification, are permitted provided that the following conditions are met:
#               * Redistributions of source code must retain the above copyright
#                 notice, this list of conditions and the following disclaimer.
#               * Redistributions in binary form must reproduce the above copyright
#                 notice, this list of conditions and the following disclaimer in the
#                 documentation and/or other materials provided with the distribution.
#               * Neither the name of the Jamf nor the names of its contributors may be
#                 used to endorse or promote products derived from this software without
#                 specific prior written permission.
#       THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
#       EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
#       WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
#       DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
#       DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
#       (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
#       LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
#       ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
#       (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
#       SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# This script was designed to be used in a Self Service policy to ensure specific
# requirements have been met before proceeding with an inplace upgrade of the macOS,
# as well as to address changes Apple has made to the ability to complete macOS upgrades
# silently.
# VERSION: v2.7.2.1
# REQUIREMENTS:
#           - Jamf Pro
#           - macOS Clients running version 10.10.5 or later
#           - macOS Installer 10.12.4 or later
#           - eraseInstall option is ONLY supported with macOS Installer 10.13.4+ and client-side macOS 10.13+
#           - Look over the USER VARIABLES and configure as needed.
# For more information, visit https://github.com/kc9wwh/macOSUpgrade
# Written by: Joshua Roskos | Jamf
# Created On: January 5th, 2017
# Updated On: September 28th, 2018
# Modified On: Novemeber 8th, 2018
# By: Lotusshaney
# MODIFICATION:
#     Added where if the user is Filevault 2 enabled and a standard user it will
#     the user to Admin to get around osinstallersetupd prompting for Admin credientials.
#     Once the installer has completed it utilizes a LaunchDaemon that will demote the
#     user back to standard and cleanup the script.
# USER VARIABLES
##Specify path to OS installer. Use Parameter 4 in the JSS, or specify here
##Example: /Applications/Install macOS High Sierra.app
OSInstaller="$4"
##Version of Installer OS. Use Parameter 5 in the JSS, or specify here.
##Example Command: /usr/libexec/PlistBuddy -c 'Print :"System Image Info":version' "/Applications/Install macOS High Sierra.app/Contents/SharedSupport/InstallInfo.plistr"
##Example: 10.12.5
version="$5"
versionMajor=$( /bin/echo "$version" | /usr/bin/awk -F. '{print $2}' )
versionMinor=$( /bin/echo "$version" | /usr/bin/awk -F. '{print $3}' )
##Custom Trigger used for download. Use Parameter 6 in the JSS, or specify here.
##This should match a custom trigger for a policy that contains just the
##MacOS installer. Make sure that the policy is scoped properly
##to relevant computers and/or users, or else the custom trigger will
##not be picked up. Use a separate policy for the script itself.
##Example trigger name: download-sierra-install
download_trigger="$6"
##MD5 Checksum of InstallESD.dmg
##This variable is OPTIONAL
##Leave the variable BLANK if you do NOT want to verify the checksum (DEFAULT)
##Example Command: /sbin/md5 /Applications/Install macOS High Sierra.app/Contents/SharedSupport/InstallESD.dmg
##Example MD5 Checksum: b15b9db3a90f9ae8a9df0f81741efa2b
installESDChecksum="$7"
##Valid Checksum?  O (Default) for false, 1 for true.
validChecksum=0
##Unsuccessful Download?  0 (Default) for false, 1 for true.
unsuccessfulDownload=0
##Erase & Install macOS (Factory Defaults)
##Requires macOS Installer 10.13.4 or later
##Disabled by default
##Options: 0 = Disabled / 1 = Enabled
##Use Parameter 8 in the JSS.
eraseInstall="$8"
if [[ "${eraseInstall:=0}" != 1 ]]; then eraseInstall=0 ; fi
#macOS Installer 10.13.3 or ealier set 0 to it.
if [ "$versionMajor${versionMinor:=0}" -lt 134 ]; then
    eraseInstall=0
##Enter 0 for Full Screen, 1 for Utility window (screenshots available on GitHub)
##Full Screen by default
##Use Parameter 9 in the JSS.
userDialog="$9"
if [[ ${userDialog:=0} != 1 ]]; then userDialog=0 ; fi
##Title of OS
##Example: macOS High Sierra
macOSname=$(/bin/echo "$OSInstaller" | /usr/bin/sed 's/^/Applications/Install (.*).app$/1/')
##Title to be used for userDialog (only applies to Utility Window)
title="$macOSname Upgrade"
##Heading to be used for userDialog
heading="Please wait as we prepare your computer for $macOSname..."
description="This process will take approximately 5-10 minutes.
Once completed your computer will reboot and begin the upgrade."
##Description to be used prior to downloading the OS installer
dldescription="We need to download $macOSname to your computer, this will
take several minutes."
##Jamf Helper HUD Position if macOS Installer needs to be downloaded
##Options: ul (Upper Left); ll (Lower Left); ur (Upper Right); lr (Lower Right)
##Leave this variable empty for HUD to be centered on main screen
dlPosition="ul"
##Icon to be used for userDialog
##Default is macOS Installer logo which is included in the staged installer package
icon="$OSInstaller/Contents/Resources/InstallAssistant.icns"
# FUNCTIONS
downloadInstaller() {
    /bin/echo "Downloading macOS Installer..."
    /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper
        -windowType hud -windowPosition $dlPosition -title "$title" -alignHeading center -alignDescription left -description "$dldescription"
        -lockHUD -icon "/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/SidebarDownloadsFolder.icns" -iconSize 100 &
    ##Capture PID for Jamf Helper HUD
    jamfHUDPID=$!
    ##Run policy to cache installer
    /usr/local/jamf/bin/jamf policy -event "$download_trigger"
    ##Kill Jamf Helper HUD post download
    /bin/kill "${jamfHUDPID}"
verifyChecksum() {
    if [[ "$installESDChecksum" != "" ]]; then
        osChecksum=$( /sbin/md5 -q "$OSInstaller/Contents/SharedSupport/InstallESD.dmg" )
        if [[ "$osChecksum" == "$installESDChecksum" ]]; then
            /bin/echo "Checksum: Valid"
            validChecksum=1
            return
            /bin/echo "Checksum: Not Valid"
            /bin/echo "Beginning new dowload of installer"
            /bin/rm -rf "$OSInstaller"
            /bin/sleep 2
            downloadInstaller
        ##Checksum not specified as script argument, assume true
        validChecksum=1
        return
cleanExit() {
    /bin/kill "${caffeinatePID}"
    exit "$1"
# SYSTEM CHECKS
##Caffeinate
/usr/bin/caffeinate -dis &
caffeinatePID=$!
##Get Current User
currentUser=$( /usr/bin/stat -f %Su /dev/console )
##Get Current Users homefolder
currentUserHomeDirectory=$( /usr/bin/dscl . -read "/users/$currentUser" NFSHomeDirectory | cut -d " " -f 2 )
##Check if FileVault Enabled
fvStatus=$( /usr/bin/fdesetup status | head -1 )
##Check if current user is an admin
/usr/bin/dscl . read /Groups/admin GroupMembership |  tr ' ' '
' | grep -x "$currentUser"
if [[ $? -ne 0 ]] ; then
    if [[ "$fvStatus" == "FileVault is On." ]] ; then
        /bin/echo "FV is on and OS User is not an Admin.  Adding $currentUser to Admin group"
        /usr/sbin/dseditgroup -o edit -a "$currentUser" -t user admin
        /bin/echo "Demote token file added for $currentUser at $currentUserHomeDirectory/.demoteafterupgrade"
        /usr/bin/touch "$currentUserHomeDirectory"/.demoteafterupgrade
##Check if device is on battery or ac power
pwrAdapter=$( /usr/bin/pmset -g ps )
if [[ ${pwrAdapter} == *"AC Power"* ]]; then
    pwrStatus="OK"
    /bin/echo "Power Check: OK - AC Power Detected"
    pwrStatus="ERROR"
    /bin/echo "Power Check: ERROR - No AC Power Detected"
##Check if free space > 15GB
osMajor=$( /usr/bin/sw_vers -productVersion | /usr/bin/awk -F. '{print $2}' )
osMinor=$( /usr/bin/sw_vers -productVersion | /usr/bin/awk -F. '{print $3}' )
if [[ $osMajor -eq 12 ]] || [[ $osMajor -eq 13 && $osMinor -lt 4 ]]; then
    freeSpace=$( /usr/sbin/diskutil info / | /usr/bin/grep "Available Space" | /usr/bin/awk '{print $6}' | /usr/bin/cut -c 2- )
    freeSpace=$( /usr/sbin/diskutil info / | /usr/bin/grep "Free Space" | /usr/bin/awk '{print $6}' | /usr/bin/cut -c 2- )
if [[ ${freeSpace%.*} -ge 15000000000 ]]; then
    spaceStatus="OK"
    /bin/echo "Disk Check: OK - ${freeSpace%.*} Bytes Free Space Detected"
    spaceStatus="ERROR"
    /bin/echo "Disk Check: ERROR - ${freeSpace%.*} Bytes Free Space Detected"
##Check for existing OS installer
loopCount=0
while [[ $loopCount -lt 3 ]]; do
    if [ -e "$OSInstaller" ]; then
        /bin/echo "$OSInstaller found, checking version."
        OSVersion=$(/usr/libexec/PlistBuddy -c 'Print :"System Image Info":version' "$OSInstaller/Contents/SharedSupport/InstallInfo.plist")
        /bin/echo "OSVersion is $OSVersion"
        if [ "$OSVersion" = "$version" ]; then
          /bin/echo "Installer found, version matches. Verifying checksum..."
          verifyChecksum
          ##Delete old version.
          /bin/echo "Installer found, but old. Deleting..."
          /bin/sleep 2
          downloadInstaller
        if [ "$validChecksum" == 1 ]; then
            break
        downloadInstaller
    unsuccessfulDownload=1
    ((loopCount++))
done
if (( unsuccessfulDownload == 1 )); then
    /bin/echo "macOS Installer Downloaded 3 Times - Checksum is Not Valid"
    /bin/echo "Prompting user for error and exiting..."
    /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -title "$title" -icon "$icon" -heading "Error Downloading $macOSname" -description "We were unable to prepare your computer for $macOSname. Please contact the IT Support Center." -iconSize 100 -button1 "OK" -defaultButton 1
    cleanExit 0
# CREATE FIRST BOOT SCRIPT
/bin/mkdir -p /usr/local/jamfps
/bin/cat > /usr/local/jamfps/finishOSInstall.sh <<'EOL'
## First Run Script to remove the installer.
## Clean up files
/bin/rm -fr "$OSInstaller"
/bin/sleep 2
## Update Device Inventory
/usr/local/jamf/bin/jamf recon
## Remove LaunchDaemon
/bin/rm -f /Library/LaunchDaemons/com.jamfps.cleanupOSInstall.plist
## Remove Script
/bin/rm -fr /usr/local/jamfps
##Demote if user was not an admin before upgrade
##Get Current User
if [[ -e "$currentUserHomeDirectory"/.demoteafterupgrade ]] ; then
    /bin/echo "User was not an Admin before upgrade, Removing $currentUser from Admin group"
    /usr/sbin/dseditgroup -o edit -d "$currentUser" -t user admin
    /bin/echo "Demote token file removed for $currentUser at $currentUserHomeDirectory/.demoteafterupgrade"
    rm -f "$currentUserHomeDirectory"/.demoteafterupgrade
EOL
##Set the permission on the file just made.
/usr/sbin/chown root:admin /usr/local/jamfps/finishOSInstall.sh
/bin/chmod 755 /usr/local/jamfps/finishOSInstall.sh
# LAUNCH DAEMON
/bin/cat << EOF > /Library/LaunchDaemons/com.jamfps.cleanupOSInstall.plist
<plist version="1.0">
<dict>
    <key>Label</key>
    <string>com.jamfps.cleanupOSInstall</string>
    <key>ProgramArguments</key>
    <array>
        <string>/bin/bash</string>
        <string>-c</string>
        <string>/usr/local/jamfps/finishOSInstall.sh</string>
    </array>
    <key>RunAtLoad</key>
    <true/>
</dict>
</plist>
EOF
/usr/sbin/chown root:wheel /Library/LaunchDaemons/com.jamfps.cleanupOSInstall.plist
/bin/chmod 644 /Library/LaunchDaemons/com.jamfps.cleanupOSInstall.plist
# LAUNCH AGENT FOR FILEVAULT AUTHENTICATED REBOOTS
##Determine Program Argument
if [[ $osMajor -ge 11 ]]; then
    progArgument="osinstallersetupd"
elif [[ $osMajor -eq 10 ]]; then
    progArgument="osinstallersetupplaind"
/bin/cat << EOP > /Library/LaunchAgents/com.apple.install.osinstallersetupd.plist
<dict>
    <key>Label</key>
    <string>com.apple.install.osinstallersetupd</string>
    <key>LimitLoadToSessionType</key>
    <string>Aqua</string>
    <key>MachServices</key>
    <dict>
        <key>com.apple.install.osinstallersetupd</key>
        <true/>
    </dict>
    <key>TimeOut</key>
    <integer>300</integer>
    <key>OnDemand</key>
    <true/>
    <array>
        <string>$OSInstaller/Contents/Frameworks/OSInstallerSetup.framework/Resources/$progArgument</string>
    </array>
</dict>
</plist>
EOP
/usr/sbin/chown root:wheel /Library/LaunchAgents/com.apple.install.osinstallersetupd.plist
/bin/chmod 644 /Library/LaunchAgents/com.apple.install.osinstallersetupd.plist
# APPLICATION
if [[ ${pwrStatus} == "OK" ]] && [[ ${spaceStatus} == "OK" ]]; then
    ##Launch jamfHelper
    if [ ${userDialog} -eq 0 ]; then
        /bin/echo "Launching jamfHelper as FullScreen..."
        /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType fs -title "" -icon "$icon" -heading "$heading" -description "$description" &
        jamfHelperPID=$!
        /bin/echo "Launching jamfHelper as Utility Window..."
        /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -title "$title" -icon "$icon" -heading "$heading" -description "$description" -iconSize 100 &
        jamfHelperPID=$!
    ##Load LaunchAgent
    if [[ ${fvStatus} == "FileVault is On." ]] && [[ ${currentUser} != "root" ]]; then
        userID=$( /usr/bin/id -u "${currentUser}" )
        /bin/launchctl bootstrap gui/"${userID}" /Library/LaunchAgents/com.apple.install.osinstallersetupd.plist
    ##Begin Upgrade
    /bin/echo "Launching startosinstall..."
    ##Check if eraseInstall is Enabled
    if [[ $eraseInstall == 1 ]]; then
        eraseopt='--eraseinstall'
        /bin/echo "   Script is configured for Erase and Install of macOS."
    osinstallLogfile="/var/log/startosinstall.log"
    if [ "$versionMajor" -ge 14 ]; then
        eval /usr/bin/nohup ""$OSInstaller/Contents/Resources/startosinstall"" "$eraseopt" --agreetolicense --nointeraction --pidtosignal "$jamfHelperPID" >> "$osinstallLogfile" &
        eval /usr/bin/nohup ""$OSInstaller/Contents/Resources/startosinstall"" "$eraseopt" --applicationpath ""$OSInstaller"" --agreetolicense --nointeraction --pidtosignal "$jamfHelperPID" >> "$osinstallLogfile" &
    /bin/sleep 3
    ## Remove Script
    /bin/rm -f /usr/local/jamfps/finishOSInstall.sh
    /bin/rm -f /Library/LaunchAgents/com.apple.install.osinstallersetupd.plist
    /bin/echo "Launching jamfHelper Dialog (Requirements Not Met)..."
    /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -title "$title" -icon "$icon" -heading "Requirements Not Met" -description "We were unable to prepare your computer for $macOSname. Please ensure you are connected to power and that you have at least 15GB of Free Space.
    If you continue to experience this issue, please contact the IT Support Center." -iconSize 100 -button1 "OK" -defaultButton 1
cleanExit 0
We just ran this script under a policy with all the Parameters defined. Our FileVault2 encrypted MacBook finally went to the installer without an Admin pw prompt! We verified the computer was updated to Mojave, but haven't got a chance to run through the computer to check for problems (it's Friday, I'm working late enough already...)
Hopefully this helps any others trying to upgrade to Mojave! And if you do use this method, please share your experiences!
As with anything else, please test before you deploy this script...
