MS changed version numbering for 2016
  • January 18, 2018
  • 40 replies
  • 242 views
rstasel
Hi All,
As I'm sure many of you will notice soon, MS changed their version numbering for Office 2016. Rather than 15.x, the latest patches are now 16.9.
This breaks all my Smart group logic... since now I have to look for two completely different versions. Licensed software also is a bit weird now.
How are people handling this? Just duplicating their licensed software profile, and smart groups, then setting policies to look at both, or...?
Best answer by mm2270
If you need it to be in one Smart Group, you can try this:
    Application Title | has | Microsoft Excel.app
and Application Version | like | 15.
or  Application Title | has | Microsoft Excel.app
and Application Version | like | 16.
and Application Version | not like | 16.9
In my quick tests, that seems to pull up Macs running any 15.x version and ones running a 16.x version that is not like 16.9.x.
unknown_err
  • January 18, 2018
Just adding the new version after an OR operator works for us.
rstasel
  • January 18, 2018
So I tried that, and had this:
Zero results. What you have, unless you're clearing the history for patches, would apply all the time, no?
unknown_err
  • January 18, 2018
Well, that group I showed is used for showing whether a computer has Outlook 2016 installed at all. We use Jamf's Patch Reporting definitions for the patch related smart groups and just set it as Patch Reporting: Microsoft Outlook 2016 is Less Than 16.9 (or whatever the latest version is that we're looking for).
The definition hasn't been updated by Jamf yet though, so it's currently still set to 15.41 for us.
  • January 18, 2018
rstasel
  • January 18, 2018
KK. We have some issues with patch reporting (we're set up as sites of a central JSS), so creating patch reporting reports doesn't work unless it's done by the central admin.
Anyway, do you see anything wrong with the logic of the group I showed? don't get why it would be 0 results.
unknown_err
  • January 18, 2018
Try removing the parentheses in the criteria. Although it makes sense to include them, we've seen it cause there to be zero results or incorrect results. See if it gives the results you expect. If not, you may need to try moving the criteria that's excluding 16.9 above the two versions you're looking for.
I would also add a . after the 15 and 16 in your criteria so that it's only looking for versions like 15.x or 16.x rather than any version with 15 or 16 in the number.
rstasel
  • January 18, 2018
Created a separate group that looks for version 16, and not 16.9, then created a parent group that checks for membership of either.
Cleaner to do that way anyway. =/ Really really really wish groups were referenced by ID, and not their name... I really want to clean up my group names. =(
bpavlov
  • January 18, 2018
I could be mistaken but you shouldn't really have to change anything in your current smart groups except updating the major version number to be "like 16.9.". At the end of the day, when you push out the new version of Office 2016, it will simply replace the current app bundles and version 15 will cease to exist on the device. Check the example in the attached screenshot which is a smart group for computers that are out of date/not running the latest version of Office 2016.
donmontalvo
Forum|alt.badge.img+36
  • January 19, 2018
  • January 19, 2018
Isn't version 16 technically supposed to be the start of Microsoft Office 2019 instead of 2016? Might want to ask on the #microsoft-office channel in Slack.
Microsoft's Office 365 subscription license is certainly making for some version questions.
talkingmoose
  • Community Manager
  • January 19, 2018
@prbsparx, version "16.x" and the "2016" or "2019" product names are unrelated. This is a change from the way Microsoft has named and versioned its products.
I'm reposting a message that @pbowden relayed to us on Slack. It may help you understand what to expect.
Here's the skinny on how things are going to play out this year. For the July update (which will be 16.15) it'll be business as usual and you'll still see the '2016' moniker for updates. However, life is going to get interesting on 8/14. If you're activated with an O365 Subscription (as per the about box), and on 10.13.2 or later, you will be offered the 16.16 update and no '2016' moniker. If you're anything else, such as VL/Retail, or Subscription and <10.13.2, you'll be offered 16.15.1 with the '2016' moniker. From there on out, you'll either be on the 16.15.x (legacy 2016) track, or 16.16+ (365/2019) track.
This all relates to licensing, which is either subscription (Office 365) or perpetual (volume license and those cards sold in retail stores). Office 365 is updating monthly and will continue updating so long as you keep your subscription active. Keeping the year in the product name doesn't make sense any more.
However, perpetual licenses are a one-time product purchase and you own that license for that one version forever. Microsoft is keeping the year in the product name for those. So, a customer can decide to purchase "2016", skip buying "2019" and later purchase "2022(?)".
After September 2020, Microsoft will cease supporting any perpetual license that's still named "2016".
https://support.microsoft.com/en-us/lifecycle/search?alpha=Microsoft%20Office%20Standard%202016%20for%20Mac
  • August 15, 2018
@talkingmoose I agree... but this is a benefit developer vs benefit all users kind of thing.
I understand that microsoft is moving to a perpetual subscription license.
But every company on the planet that I know increments the major version number when there is a Major change/new license associated with it.
In Jamf Pro to do proper validation of the 2016 vs 2019 - we now have to create a patch title to even do comparisons.
The ability to use Licensed Software is gone.
I now have to explain to users that, oh yeah... You doing Fast Insider broke your ability to use Office 2016 cause they behind the scenes without any major warning to you upgraded you to 2019. Oh, and I have no easy way to pull a list of all the users experiencing it.
Proper version control is as much for developers as for users.
v15 and v16 being Office 2016, fine.
v16.15+ being Office 2019??? I require a new license, a majority of the software changes significantly for volume license customers. This just seemed like someone didn't consider the user impact.
We need a way to track this without having to track the specific license associated. Someone can have the Office 2016 license installed, but the Office 2019 apps...
  • August 15, 2018
@talkingmoose Apparently I missed this post by Paul but if I'm reading right, I should be on the 16.15.x track. I currently have 16.15 installed but AutoUpdate started prompting me this morning to install 16.16. I don't have time at the moment to update and see what happens but this doesn't match up with what I think Paul is saying there.
This would be the time for you or someone to tell me that I'm simply reading this wrong. It's been one of those months. lol
talkingmoose
  • Community Manager
  • August 15, 2018
@prbsparx, whew! A lot to cover. 😃
I'm going to steal Paul Bowden's (@pbowden) term "generation" to mean a specific major version of an Office product (e.g. Office 2008 or 2011 or 2016 or 2019). Paul's the major Mac architect for Microsoft facilitating all of these product version/name changes you're seeing.
First, just a clarification: perpetual and subscription are opposite types of licenses. If someone buys a perpetual license, he or she is allowed to use that "generation" (e.g. Office 2008, 2011, 2016 or 2019) of product forever. As with most developers, a perpetual license for one generation doesn't include a license to use the next generation. A subscription license allows you to use the current product until you decide to stop using it. Subscription has no generation associated with it. It is what it is at that point in time you're paying for it.
WHY CHANGE VERSION NUMBERS?
You're absolutely correct Microsoft is changing how they version their products. I'm not here to defend nor renounce the changes. They are what they are. I can tell you, though, they're not making these changes arbitrarily. Once you understand the full picture of any situation, you'll sometimes find you're left choosing the lesser of two evils.
The largest factor in this, which you probably never noticed, is that back in January Microsoft released for the first time ever an Office for Mac product that was built on code shared across Mac, Windows, iOS, Android and that other phone OS. Some of those OS platforms are old. Some are new. They decided that was the time to synchronize version numbers. It had nothing to do with the product customers received. It had everything to do with them trying to align things internally for future plans.
The other factor in this whole scenario is that Microsoft is now selling licenses in two ways instead of one. We've had perpetual licensing for years. Subscription licensing is new. This is really the first time they've had to decide how all of this upgrade thing is going to work. They don't want to keep offering updates for perpetual license customers because at some point they need to recoup their development costs. (Subscription allows them to do this monthly.) So, they had to draw a line in the sand and say "2016" stops here and "2019" starts here. That directly translates to "2016" stops at version "16.16" and "2019" starts at "16.17".
INSIDER FAST BEHAVIOR
What happens with Insider Fast customers with volume licenses? Microsoft AutoUpdate is not suppose to update any Volume License customer with a 2016 (or v2) license to 16.17. There was a period, though, about 10 days ago when this could have happened. If you're seeing this happen today, please report it to Paul in the #microsoft-office channel in the MacAdmins Slack team. That's our batphone into the Office for Mac team at Microsoft.
If you have a user who was accidentally updated to 16.17 via Insider Fast and is running a volume license, you have a couple of options:
  1. Install the 2019 Preview VL Serializer from the MS Collaborate website.
  2. Drag the v16.17 applications to the Trash, install v16.16 from https://macadmins.software and disable the Insider setting in Microsoft AutoUpdate.
The final 2019 VL Serializer will be available September 24 on the Microsoft Volume License Service Center.
TRACKING WHAT'S INSTALLED
Yes, we need a way to track all of this in Jamf Pro. We can already get version numbers as part of inventory and Paul has written tools that help us know which license is being used on a Mac. He's also planning to update his tools and will soon release a video tutorial for Mac admins to help us understand all of this.
BE PREPARED
As far as user impact, I think that's negligible (other than someone who was inadvertently updated to 16.17 with a v2 volume license). Subscription customers continue receiving updates and perpetual customers no longer receive updates without purchasing a new license. The real impact is to us as administrators and we have Microsoft proactively working to help us understand and plan for all of this.
Keep an eye on the #microsoft-office channel in the MacAdmins Slack team. Keep an eye out here too. A few of us will do our best to keep folks informed and prepared. Paul and Jamf are in regular communication with each other. We're all preparing for these changes.
One last thing, if you're coming to the Jamf Nation User Conference (JNUC) this October, come chat with Paul and Jeff Kalvass (Product Manager for Outlook for Mac) at 2:45 p.m. on Wednesday. We'd love to see everyone. I'm hoping to also plan an evening mini-event for even more time with them. Stay tuned.
talkingmoose
  • Community Manager
  • August 15, 2018
@jhuls, if you haven't enabled your Mac for the Insider program in Microsoft AutoUpdate, then you're on the "production" channel. This is what most customers should be using.
The production channel releases 16 days after the last Sunday of the prior month. That's always a Tuesday. (Sometimes it corresponds to Microsoft's Patch Tuesday for Windows. Sometimes it doesn't.)
If I whip out the Terminal application and run cal July 2018 and cal August 2018, I see:
        July                   August
Su Mo Tu We Th Fr Sa    Su Mo Tu We Th Fr Sa
 1  2  3  4  5  6  7              1  2  3  4
 8  9 10 11 12 13 14     5  6  7  8  9 10 11
15 16 17 18 19 20 21    12 13 14 15 16 17 18
22 23 24 25 26 27 28    19 20 21 22 23 24 25
29 30 31                26 27 28 29 30 31
August 14 (yesterday) falls 16 days after July 29 and is when version 16.16 was released. You're right on time.
dpertschi
Forum|alt.badge.img+19
  • August 16, 2018
So, if someone is a O365 customer and in the habit of installing the full suite each month to patch; does that mean I'd have to start installing the 365 Suite Installer on 10.13.2+ and the 2016 Suite Installer on <10.13.2?
talkingmoose
  • Community Manager
  • August 16, 2018
@dpertschi, first let’s clear up the versions from the earlier announcement. Version 16.16 released this week for the month of August. That will be the last of the “2016” generation. Next month, version 16.17 releases and will be the first of the “2019” generation.
What happens to 16.16 going forward?
If your software is activated using a product key from the back of a scratch-off card and you choose not to purchase “2019”, then your software will continue to receive security and bug fixes until late 2020, which is its planned end-of-life. Microsoft will still support the “2016” generation, but it will no longer receive any new features. Next month’s “2016” generation update will be version 16.16.1. The month after will be 16.16.2, etc.
If your software is activated using a Volume License that is part of a Microsoft enterprise licensing agreement, your company likely pays an annual fee and it’s probably renewed annually already. Administrators will be able to download the 2019 VL Serializer (similar to the one we have today) and that will allow you to continue updating to 16.17, 16.18 and so on. The 2019 VL Serializer will be available in September.
If your Office software is activated using an Office 365 license (you signed in with your Office 365 account to activate), then you can simply allow Microsoft AutoUpdate to move you to 16.17 next month or download the full 16.17 installer and apply it as an update. Of course, Microsoft would Ike you to install the latest version with the latest features and fixes.
To answer your question: Yes, this means we’ll now have two full installers going forward:
  1. Office 2016 for Mac 16.16.x
  2. Office 2019 for Mac 16.17+
However, the version of macOS is very forgiving. For legal reasons, Microsoft is committed to supporting 2016 all the way back to OS X 10.10.
For 2019 going forward, though, it will only support macOS n-1. That means the current version of macOS plus the last version of macOS. (I suspect by “last version of macOS” they actually mean the latest release of the last version.)
For right now, you only need to be concerned that your version of Office for Mac is compatible with your chosen licensing.
  • August 16, 2018
@talkingmoose Thanks for clearing the version information up. For whatever reason the statement from Paul had me confused.
dpertschi
  • August 21, 2018
As I unpack it a bit more, this is important, and folks might want to feedback to MS if you're not keen on N-1.
Next month our Sierra 10.12 machines will be able to update to the 2019 generation with version 16.17. But be aware that come January you'll be stuck at version 16.21 (no more security updates) until you upgrade the OS.
If you (like me) expect to be maintaining Sierra on your network next year, we have a month to decide whether or not to hold them back in the 2016 generation (in order to receive security updates) or plow forward and get them updated to 10.13+ early in the new year.
I've got 1000 Sierra machines today, must satisfy SecOps, can't get them all upgraded by Feb, am not keen on handling both 2016 and 2019 installer/patch packages. Come with me, send feedback to MS to reconsider N-2 support for 2019.
rstasel
  • August 21, 2018
Do you have a ticket you've submitted for this, or a location where you're submitting this?
I would also like to see N-2 since that's Apple's (un)official line...
dpertschi
  • August 22, 2018
rstasel
  • September 12, 2018
okay, so here's another question: anyone else seeing 16.16.2 (16.16.2018091001) show up in patch reporting yet? Wonder how Jamf is going to handle the version number divergence.
Seeing new version now.
chris_kemp
Forum|alt.badge.img+21
  • September 17, 2018
@rstasel Can you clarify, are you seeing 16.16.2 or 16.17 now?
rstasel
  • September 18, 2018
@chris.kemp I am only seeing 16.16.2 (16.16.18091001)
donmontalvo
  • September 21, 2018
I hope the Patch curators are going to tread carefully...16.17 (2019) is not going to support 16.16.2 (2016) Volume Licensing.
PS, corrected my statement.
