Redneck iPad Setup help
KyleEricson
Valued Contributor II
I want to be able to have an iPad on wired ethernet and an HDMI adapter.
I have tried lots of Apple adapters and no luck. Is there some way to do this, maybe with the Apple USB-C HDMI adapter.
What I have tried:
Apple= AP
AP iPad HDMI Adapter-->AP 3.0 Camera adapter--->AP USB 2.0 ethernet adapter =Video no IP on ethernet
Seems like the HDMI has to be first in the chain for it to work
AP iPad HDMI Adapter-->3rd party USB+Lighting+Ethernet= Video works no IP on ethernet
I need this for a factory floor application where I need an ethernet iPad and video displayed to the external monitor.
So please break out the bluegrass and any red neck ideas are welcome.
Read My Blog: https://www.ericsontech.com
7 REPLIES 7
jhalvorson
Valued Contributor
Add an AppleTV to the mix. Connect the AppleTV to the monitor. Use AirPlay to send the video from the iPad to the AppleTV.
Hugonaut
@kericson alrighty, here's a redneck solution. I think you need to get rid of the apple usb to ethernet connecter
  1. Connect this to ipad - https://www.amazon.com/Apple-Lightning-Digital-Adapter-MD826AM/dp/B009WHV3BM
  2. Connect HDMI & then connect lightning to this - https://www.amazon.com/Lighting-FA-STAR-Interface-Required-Upgraded/dp/B075V1ZY2C/ref=sr_1_3?ie=UTF8...
  3. Connect power to charge, connect usb to this - https://www.amazon.com/AmazonBasics-1000-Gigabit-Ethernet-Adapter/dp/B00M77HMU0/ref=sr_1_7?ie=UTF8&q...
  4. Connect Ethernet to that
OR
HDMI + Lightning to Lightning to USB & lightning -> Connect USB to MacBook hardwired and sharing ethernet to 'USB iPhone adapter'
________________
Looking for a Jamf Managed Service Provider? Look no further than Rocketman
________________
Virtual MacAdmins Monthly Meetup - First Friday, Every Month
KyleEricson
@Hugonaut Ok the first one I have already tried with the 3 Apple adapters, no ethernet connection. Can you explain the last option better? @jhalvorson Will Airplay turn off after so long if the iPad never goes to sleep?
Hugonaut
Im thinking you can Connect the iPad to the dual Hdmi & Lightning female adapter, Connect the HDMI Male adapter, then connect a male lightning to male usb, connect male usb into a hardwired macbook. Under sys prefs -> sharing -> Internet Sharing - select 'Share your connect from " Ethernet " ' ' to "computers using" "iPhone USB" '
This way, the iPads Charged, Hooked up to External HD Monitory & getting ethernet internet access from the macbook.
________________
________________
KyleEricson
Tested that didn't work either and AirPlay is out. Does anyone know if you get a lightening splitter will only one side to data and the other power?
KyleEricson
Has anyone tested this Read Here
I can't get it to work on iOS 11.4 and iOS 12.1
KyleEricson
Or has anyone gotten a USB to VGA or HDMI external graphics card adapter to work with a iPad. Then I could use a USB hub for everything.
