Remote Classroom Management apps for 1-2-1 Dyknow vs Impero
  • November 30, 2020
  • 71 views
Hey all,
We are starting to look at services like dyknow and Impero to help our staff remotely manage the student devices and I just wanted to check if anyone is using those (or others) and what your experience is like?
Gabe Shackney
Princeton Public Schools
  • September 22, 2023
Hi Gabe,
So here we are 3 years later, how is Dyknow going? One issue we have is with students turning off permissions to it. Have you had any success in finding a way to prevent them from turning the features off to prevent it from working properly?
We didnt go with either option as both seemed to have many issues at the time.  We do use go guardian and lock students into the chrome browser as as well as apple classroom.
  • July 25, 2024
Hi Gabe,
Hello, have you found a way to prevent students from turning Dyknow off in Screen & System Audio Recording? Trying to not completely disable Privacy & Security.
Thanks in advance.
