OpenSSH < 9.9p2 DoS
  • March 7, 2025
  • 4 replies
  • 52 views
Does anyone know how to fix this vulnerability on Mac without installing homebrew on machine ?
AJPinto
  • March 7, 2025
Installing it through Homebrew will not help, as that installs a separate SSH binary and does not update the one bundled in with macOS.
Do you have a link to the vulnerability or the NIST details? We disabled SSH years ago on macOS due to vulnerabilities and Apple being very slow to patch SSH.
  • March 10, 2025
Don't have NIST details. But hope this will help you. https://www.openssh.com/txt/release-9.9p2
Shyamsundar
  • March 11, 2025
if I am not wrong, even though you install with Homebrew it will not patch the existing one, it will install a new one with the latest version, you need to wait for Apple to release an update, did you tried it with the latest beta version 15.4 beta 3 and check the openSSh version
  • March 17, 2025
Yes tried with 15.3 it shows SSH 9.8 version
