ASAM on macOS
  • July 17, 2025
  • 0 replies
  • 105 views
spokta
Hello,
I'm currently working on implementing Autonomous Single App Mode (ASAM) on macOS and have been following the official Apple documentation:
I've configured and deployed the ASAM profile to a Mac using Jamf, but unfortunately, the target app does not launch automatically, and the system does not appear to enter ASAM as expected.
Here is the profile I’ve been using:
<plist version="1.0">
<dict>
  <key>PayloadContent</key>
  <array>
    <dict>
      <key>PayloadType</key>
      <string>com.apple.asam</string>
      <key>PayloadVersion</key>
      <integer>1</integer>
      <key>PayloadIdentifier</key>
      <string>com.test.lockscreenapp.asam</string>
      <key>PayloadUUID</key>
      <string>c324fd3e-d98a-4ea8-818a-5991024cddd0</string>
      <key>PayloadDisplayName</key>
      <string>ASAM - Lockscreen</string>
      <key>PayloadEnabled</key>
      <true/>
      <key>AllowedApplications</key>
      <array>
        <dict>
          <key>BundleIdentifier</key>
          <string>com.test.LockscreenApp</string>
          <key>TeamIdentifier</key>
          <string>YOUR_TEAM_ID</string>
        </dict>
      </array>
    </dict>
  </array>
  <string>Configuration</string>
  <string>com.okta.lockscreenapp.profile</string>
  <string>467ab3a0-9423-4c16-a05c-5c99d771088f</string>
  <string>Lockscreen ASAM Profile</string>
  <key>PayloadOrganization</key>
  <string>TestingApp</string>
  <key>forceASAMAppBundleID</key>
  <array>
  </array>
</dict>
</plist>
Despite the profile being successfully installed, the system doesn’t enter ASAM and doesn’t launch the specified app.
Has anyone successfully deployed and tested ASAM on macOS? Specifically:
  • Are there any required APIs or Info.plist keys the app must implement?
  • Is there a way to programmatically monitor or validate that ASAM was triggered on the device?
  • Does the app need to be signed in a specific way or trigger an event upon launch?
Any insights or examples would be greatly appreciated.
Thank you!
