Jamf Connect 2.4.5 Local Password Prompt Issue
  • August 24, 2024
  • 13 views
Hi everyone'
 I recently updated to Jamf Connect 2.4.5, and now I’m having trouble with the Local Password prompt. It seems like the prompt is not working correctly after the update.   give any suggestions for fixing it ? how to resolve this problem. Thank you all !
1 reply
AJPinto
  • August 24, 2024
We will need a lot more information to assist. Also, was it a typo with Jamf Connect 2.4.5? The current version of Jamf current is 2.36, if you are just on 2.4 you really need to get to 2.36 before troubleshooting anything.
For starters, lets gather this information and see if anyone has anything.
  1. What is your IDP?
  2. What is the prompt doing or not doing which is making you think it's working incorrectly?
