We're working on moving one of our labs from a Deepfreeze setup to an AD setup. Most of this is figured out acceptably well. The two things that I'm having trouble figuring out are Safari settings and screensaver settings.
We need to have four homepages and potentially a set of bookmarks for all users. I've figured out setting one homepage, but it seems to not work at all with four. In Safari itself, it seems to use a unique "Tabs with favorites" setting to open multiple homepages. That would be fine if I could figure out how to set those tabs through a plist or something. What would be the best way to push out management settings on this?
The screensaver needs to be the built in Reflections with a folder we specify that is on all machines and accessible by all users. The problem is the only way I've found to manage screensaver settings is through MCX, which works but for some reason will not apply the Reflections screensaver specifically. Also Apple keeps saying that MCX will go away at some point in the future, but never seems to actually follow through with that threat. I'd love a way to set it up without using MCX if possible.
Anyone have ideas on either of those? Also game for general tips on swapping over to AD.
