10.15 Catalina security authorizationdb doesn't work as advertised
  • October 11, 2019
  • 4 replies
  • 29 views
/usr/bin/security authorizationdb read system.login.screensaver >/tmp/originalss.$$ /usr/bin/sed 's/use-login-window-ui/authenticate-session-owner-or-admin/' /tmp/originalss.$$ >/tmp/newss.$$ /usr/bin/security authorizationdb write system.login.screensaver </tmp/newss.$$
The contents claim that this is still the way to do it but locking the screen never gives a dialog just black with cursor.
The owner or any administrator can unlock the screensaver, set rule to "authenticate-session-owner-or-admin" to enable SecurityAgent.
  • October 30, 2019
Still broken under 10.15.1
  • December 11, 2019
Still broken under 10.15.2
  • December 12, 2019
Does this work? Not sure why you're using sed and appending that way.
security authorizationdb write system.login.screensaver authenticate-session-owner-or-admin
Reference here - https://dssw.co.uk/reference/authorization-rights/system-login-screensaver.html
  • December 12, 2019
Not sure what my original source of the code was but the result is the same.
It might actually may be fixed in 10.15.2. Small sample though.
