We have a 10.8 image that is encrypted with Filevault 2 and are using a configuration profile to set up the wireless with the Use as a Login Window configuration option. When I boot the machine with a wired network connection and the airport turned on, it connects to the wireless with no problem. If I log off and back on after that with no wired connection, the wireless connects fine, drives map, etc. We run into a problem when we reboot (or cold boot) with no wired connection. I enter the user password at the filevault boot screen and then the machine boots and logs in with SSO. At this point it cannot connect to the wireless and gives a self-assigned IP. Log off and back on has no affect. Turning the airport off and on has no affect. However, if I plug the network cable in, the wireless connects with a valid IP after a few seconds and continues to work fine. My next tests are imaging a machine, using the same wireless profile, but no filevault to see if the problem persists. Does anyone have any other thoughts or has anyone else run into this issue?
10.8 Wireless Authentication issue
