I have a strange one-off issue.
We bind our Macs to AD (I know, I know, spare me the rhetoric about no AD on Mac. Believe me... I know).
So here's the deal...
- We have a directory binding set up in the JSS 9.81
- We have a policy that binds any unbound system to AD.
- It works on the 13" MacBook Air
- It works on the 15" Retina MacBook Pro
- As of this posting, all OS patch levels are 10.11.3 (15D21)
However...
- The MacBook Pro (Retina, 13-inch,Early 2015) [MacBookPro12,1] won't bind.
The JAMF policy fail.
JAMF Policy Logs for this machine states the following:
Executing Policy Active Directory - Bind to AD...
Binding User's MacBook Pro to domain.com...
Computer name must be less than 15 characters. (domain.com) was specified. (Attempt 1)
An error occurred binding to Active Directory: dsconfigad: The plugin encountered an error processing request. (10001). (Attempt 2)
An error occurred binding to Active Directory: dsconfigad: The plugin encountered an error processing request. (10001). (Attempt 3)
An error occurred binding to Active Directory: dsconfigad: The plugin encountered an error processing request. (10001). (Attempt 4)
An error occurred binding to Active Directory: dsconfigad: The plugin encountered an error processing request. (10001). (Attempt 5)
Error: Giving up on Active Directory binding after 5 attempts.
The computer name is 15 characters or less and meets NetBIOS requirements.
If I join the system manually via the GUI using the EXACT same settings as found in JAMF Directory Binding, the machine binds to AD without any issue.
It's only when JAMF tries to bind it does it fail and it's only on this hardware model.
Has anyone else seen this particular issue/bug before?
If so, what was your method to resolution?
P.S. - I've also checked up on https://jamfnation.jamfsoftware.com/discussion.html?id=9588 and no, it's not a clock issue. ;-)
