2016 PARCC Testing Issue
  • March 15, 2016
  • 28 views
Hi all,
In our school district we are seeing an issue with Java unable to be successfully detected in Firefox per the PARCC testing technical requirements.
  • JSS is up to date.
  • Firefox is up to date.
  • Java is running the recommended version from Oracle.
Is there a possibility that JSS is somehow obstructing the running of the Java Applet in Firefox in this particular instance?
The last discussion I saw on PARCC was January of 2015, so I was hoping to reopen the conversation with our issue(s).
Best answer by arielper
For PARCC this year we are totally going with the new published app at http://download.testnav.com so we don't have to worry about Java or browsers.
If you're inclined on sticking with a browser, I would check to see if you get the same behavior from other browsers or not to see if the problem is with FireFox or with your Java installation.
  • March 16, 2016
  • March 16, 2016
The TestNav app has worked great for us all year with the ACT Aspire test.
  • March 16, 2016
The published app is working phenomenally. But, our administrators want us to have a Plan B.
Thanks for the advice!
