802.1x Wireless Configuration Self Service Plugin Public - Beta
  • March 12, 2012
  • 7 replies
  • 37 views
external image link
I am working on an Open Source 802.1x wireless configuration script with a Cocoa Self Service plugin. If your currently using 802.1x wireless (default is PEAP) then this tool may be something you can beta test for me. If your interested in participating please do the following:
Its a Beta so things are still a little raw, so please read the README:
https://github.com/acidprime/WirelessConfig/blob/master/README
The compiled example is available in the downloads section:
https://github.com/acidprime/WirelessConfig/downloads
Please file all bugs using the public issues section for the project on github.com
Please put questions, installation issues, whatever , as you may help someone else
with your question.
https://github.com/acidprime/WirelessConfig/issues
Note: This does require a github account which is free.
The commit history is available as a atom feed, watch for updates.
https://github.com/acidprime/WirelessConfig/commits/master.atom
The final version will be posted on jamfnation after the BETA is over.
jhbush
Forum|alt.badge.img+27
  • March 13, 2012
Zach, this looks great. Does this create a profile that shows up in the pref pane? Is there a place in this that allows certs to be trusted? Does this add the user credentials to the keychain. If so how does this play with FV2 not updating that password? Thanks for all of your work on this!!!
Forum|alt.badge.img+31
  • March 13, 2012
This looks awesome, keep us posted! I would love to test it, but I may not have any free time to do so.
  • March 14, 2012
@jhbush1973 yes this generates the profile, stores it temporally on disk and then imports it with the profiles command and deletes. In 10.6 and 10.5 manually writes the preference keys ( 10.6 "profiles" code is there but did not work as well so I just manually do it ). In all cases it manually creates the OS specific keychain format. In the case of 10.7 I found that installing a System profile did not cause auto connect to occur even though the credentials were embedded in the profile. User profiles worked but caused a password prompt, so I split the difference and manually create a com.apple.network.eap.user.item.wlan.ssid.newNetwork entry in the keychain.
Per your question on certs, not yet but it will in the Final release, just trying to decide the best way to store them as I may just have it loop through the bundle, but I really wanted to keep all the info in the settings plist, so I may have to make a settings generator that correctly encodes the DER or PEM as a NSData item in the plist.
Re: FV2, I guess the best way to put it , is this is a removal and addition tool, so it clears out old creds before it adds new ones when you have the SSID added in both the add and remove arrays
  • March 15, 2012
10.6 Bug Fix Update to Python Script:
https://github.com/acidprime/WirelessConfig/commit/be884c36d03d944f2bd31956bf8b62b31089efeb
  • February 25, 2014
Any further comment on how production ready this is given that it seems to be being maintained? Also, sorry to sound like an idiot, but what is the function of the mdmh key and does it need to be customized?
  • February 26, 2014
Wow, Just what we needed.. Looks great. We run all mavericks here. Love hacking and will test. Does jamf know about this, time to wake them up.
Forum|alt.badge.img+23
  • February 26, 2014
It's good ... unless you have user authenticated 802.1X like we have. Then it's config profile only for that on Mavericks. Thanks Apple.
