Following JAMF's own whitepaper on the subject, I created my first CS5.5 Design Suite deployment package with AAMEE v2 (man that's fast!), uploaded it to Casper, sync'd distros, but the software just will NOT install in an Imaging workflow.
I've tried it right after the image lays down, and as a first run install but the apps never show up; though progress indicators appears to take a while. The Imaging logs show that it installed, and I can't find anything useful in the jamf.log on the client to suggest a point of failure.
The software package WILL install correctly when pushed via Casper Remote, with or without being logged in.
Suggestions?
thanks,
Darrin
