Is it possible to have multiple instances use the same ADCS server at the same time? I've been told yes, but the ADCS deployment appears linked to a specific cloud instance. How do you generate an additional client certificate for use with the second cloud instance of Jamf Pro?
Or maybe an additional client cert isn't needed?
Long shot, but did you ever find the answer to this question?
