I see instructions on adding printer drivers for deployment to Jamf via "Jamf Admin," but how does one add local scanner drivers package deployment to Jamf?
I have the same need, to add a scanner object to Printers pane via Jamf. How can this be accomplished?
Not likely you'll be able to use Admin for this.
You might want to open the installer using something like SuspiciousPackage review any scripts included, then package/script accordingly
