Adobe 2023 Products Fail to install
  • May 25, 2023
  • 10 replies
  • 105 views
I've been attempting to deploy the latest creative cloud software installs and encounter the following error when running the policy. Installing the PKG outside of Jamf works without issue.
Checking for policies triggered by "Acrobat2023" for user "username"...
Executing Policy Acrobat 2023
Mounting Casper_File_Share
Installing AcrobatPro2023_SDL_Install.pkg.zip...
Installation failed. The installer reported: installer: Error - the package path specified was invalid: '/Library/Application Support/JAMF/Downloads/AcrobatPro2023_SDL_Install.pkg.unzip/AcrobatPro2023_SDL_Install.pkg'.
Submitting log to https://mdm.domain.edu:8443/
Any suggestions?
  • May 25, 2023
Did you upload the .pkg via the web page? If so, you'll want to pre-compress the .PKG using the MacOS compress, then upload that file with its .ZIP extension via the web interface.   For some reason, if you let JAMF do the compression on upload, the packages will fail to install.
  • May 26, 2023
I created/downloaded the pkgs from the Adobe Admin Console site. I then copied the PKG using Jamf Admin which does the compression.
I did just test pre-compressing the pkg but get another error when initiating the policy:
Installation failed. The installer reported: installer: Package name is AcrobatPro2023_23.0_SDL
installer: Installing at base path /
installer: The install failed. (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance. An error occurred while running scripts from the package “AcrobatPro2023_SDL_Install.pkg”.)
junjishimazaki
Hi @lehose , perhaps instead of packaging you can look into using a script called Installomator. https://github.com/Installomator/Installomator
Which includes Adobe Acrobat Pro DC. Look in the readme
  • June 7, 2023
I was running into the same issue.  I removed the initial pkg I uploaded to Jamf.  Went back to the downloaded Creative Cloud Install.pkg and compressed it via Finder.  Uploaded the Creative Cloud Install.pkg.zip. Flushed the log. That finally allowed the Policy to complete.
  • June 14, 2023
I am just getting started with deploying Adobe Acrobat.  My plan was to deploy the  Creative Cloud managed pkg from the Admin Console and then deploy Adobe Acrobat via the Jamf App Catalog.  I noticed that when then Adobe Acrobat app installed it also installed the Creative Cloud app.  Is the point of the managed package just to deploy management options? Is it necessary?
  • June 14, 2023
Any package built using the adobe tools includes CC desktop app.
  • June 14, 2023
I guess my question is if I deploy Acrobat with Jamf Apps, do I still need to deploy the Adobe CC pkg downloaded from Adobe with a Profile??
FutureFacinLuke
Hi, this works for me, I am seeing the same issue with packages built by Adobe Admin Console other than the CC Desktop App. When you push out the App from Jamf Apps it will use Named Licensing so is fine for one-to-one if you also deploy a CC Desktop package with the settings you want it will switch it over to Shared Device Licensing (or the managed settings you want for Named Licensing).
FutureFacinLuke
See my answer below for bypassing a day or so of packaging/uploading if you're doing the whole suite.
I was seeing the same failures on a newish setup. While testing from Terminal I spotted a notification: "Terminal was prevented from making changes to the apps on your Mac"
Following: Allow apps to control other apps on Mac the next run installed Photoshop successfully.
This looked like a PPPC payload so I've deployed what I think is needed and it seems to be working on the first few devices.
  • August 30, 2023
Thanks for the input. The current work around I have is creating another policy that triggers a single line script that executes the custom trigger I have set on the policy that contains the pkg. So far this process seems to work from SelfService.
