Hi All,
I'm looking for the Adobe Audit custom report, but can't seem to find it in the resource kit.
Anyone got it?
Hi All,
Anyone got it?
Best answer by Cem
Adobe Audit Using Casper Suite v7.31:
Due to JAMFsoftware’s out of date AdobeAudit Custom Report Java Script. Me and the folks from JAMF managed to get the report done manually (awesomest customer support ever!!!).
Here how we created manual report from Casper by using Adobe’s Executable list for Macs (supplied by Adobe at that time, but I suggest use the list provided by Adobe to you)
• First Suppress Application titles from reports in JSS Casper Console:
• Go to settings => Inventory Options => Suppress Application
• Select all Applications and deselect Adobe Mac executable/apps from the list (supplied by Adobe, sorry I don't feel comfortable to post it here)
• Then go to Inventory => Applications
• Search these words with spaces between them. That will bring the result:
Adobe Acrobat Bridge Dreamweaver Extension Flash Freehand Illustrator Indesign VersionCue
