Airdrop no notification pops up
  • February 27, 2025
  • 13 replies
  • 922 views
Hi all. AirDrop is enabled for use between our shared iPads. However, when transferring files, the iPads emit a beep, but no notification appears to accept the transfer. Do you have any insights into what might be causing this issue? The devices are running iPadOS 18.3.1.Thanks in advance for your help!
GregBobbett
  • February 27, 2025
Just going to toss a couple ideas out.
The users will need to have Bluetooth and wi-fi enabled.
The 'Everyone for 10 minutes' option on the iPad under Settings > General > Airdrop needs to be selected.
Do you have any Jamf Profiles that are turning off Notifications?
I'll see if i can come up with any other items to look at.
  • February 28, 2025
I already checked them, and everything seems to be fine, but it still doesn’t work. I also couldn’t find any option for turnning off notifications in the profiles, and the 'Notifications' section is not configured.
Before applying the profiles, for example when the device is just turned on and still disconnected from the internet, AirDrop works. However, after connecting to the internet, the same problem occurs.
hank
  • February 28, 2025
This was actually a behaviour in one of the first iOS 18 versions in combination with a configured app safelist, if I remember correctly. It was fixed with one of the following iOS versions and it didn't occure to me again. Are you absolutely sure, that alle iPads are on iOS 18.3.1? Otherwise try deactivating the safelist and give it another try.
GregBobbett
  • February 28, 2025
I just ran across a post that mentioned that firewall setting can block airdrop as well. The post stated "Allowing TCP 8770 through it's firewall allowed AirDrop to start working." Granted this was on a Mac, but I was wondering if your internet filtering might be causing the issue. Since you said it breaks once you connect to the internet.
Just another thought. I'm not a network guy, so I don't quite understand all of that side of the equation.
  • March 5, 2025
Thank you, Greg. I just checked the post, but it doesn’t apply to our case since even non-managed devices connected to our internet can AirDrop without any issues.
  • March 5, 2025
Yes, I’m sure the iPads are on iOS 18.3.1. I deactivated both the Safelist and Blocklist, but the issue persists.
  • March 26, 2025
I was having the same issue. Airdrops works when I am sending files to other devices but when I am receiving I do get notification sound but no pop up to accept or decline. The profile that was assigned to the device via jamf had "App usage" restrictions set as "only some apps allowed". When I changed the restriction to "some apps not allowed" and added whatever restricted apps on list. The issue with airdrop got resolved. This is happening on iOS 18.3.2
  • April 8, 2025
In Jamf School, there is no "App Usage" option. Under the profile restrictions, in the ''Media Content'' tab, there's an ''Apps' section which is set to ''Allow All Apps'', but the issue still persists.
EdwardB
  • April 17, 2025
I think this is a Jamf School issue. I escalated this to Jamf School support. Maybe you should too. More complaints often works best. I think it has to do with BundleID "com.apple.Sharing.AirDropUI" not being added to the Safe App List that is installed (automatically) on the Shared iPad.
EdwardB
  • April 18, 2025
Jamf is already aware of this issue and is working on it.
  • April 22, 2025
So, we hope they solve it soon.
ricosynth
  • August 27, 2025
Adding BundleID "com.apple.Sharing.AirDropUI" under the "only some apps allowed" worked for me!
  • September 22, 2025
This worked! Thanks for this!
