I have a business requirement to monitor USB devices in particular data sticks and external drives, connected to our Macs not to disable or review the content.
Simply to record the sort of info (see below) returned when I run
''system_profiler SPUSBDataType''
through ARD.
I may also need to gather data on the size of the data transferred and generate a report on the results.
Most of our users are on Snow Leopard 10.6x, though we are about to roll out some Lion hardware.
It occurs to me I cannot be the only person required to do something like this.
Any help or pointers gratefully received.
Cheers
Phil
External HDD :
Capacity: 250.06 GB (250,059,350,016 bytes) Removable Media: Yes Detachable Drive: Yes BSD Name: disk2 Product ID: 0x0704 Vendor ID: 0x1058 (Western Digital Technologies, Inc.) Version: 1.05 Serial Number: 575848393038393536323631 Speed: Up to 480 Mb/sec Manufacturer: Western Digital Location ID: 0xfd100000 / 4 Current Available (mA): 500 Current Required (mA): 2 Partition Map Type: GPT (GUID Partition Table) S.M.A.R.T. status: Not Supported Volumes: Capacity: 209.7 MB (209,715,200 bytes) Writable: Yes BSD Name: disk2s1 Boot: Capacity: 32.77 GB (32,766,398,464 bytes) Available: 18.53 GB (18,528,997,376 bytes) Writable: Yes File System: Journaled HFS+ BSD Name: disk2s2 Mount Point: /Volumes/Boot Data : Capacity: 216.81 GB (216,814,759,936 bytes) Available: 172.73 GB (172,730,023,936 bytes) Writable: Yes File System: Journaled HFS+ BSD Name: disk2s3 Mount Point: /Volumes/Data
