App Auto-Patch 3: 17-minute Quick-start for Jamf Pro
  • April 3, 2025
  • 95 views
dan-snelson
Forum|alt.badge.img+30
The go-to, open source, “patch-nearly-every-macOS-app-I-didn’t-even-know-was-in-my-environment” now MDM-agnostic super-tool just turned three
Introduction
App Auto-Patch 3 integrates local application discovery, Installomator, and user-friendly swiftDialog prompts to automate application patch management for Mac computers.
With version 3, automation has been elevated with the introduction of several new features, including an automated background agent, settings via a configuration profile and enhanced deferral options.
The end-user experience can differ based on how you configure App Auto-Patch:
  • Completely Silent
  • Silent Discovery, Interactive Patching
  • Full Interactive
Configuration Profile
While version 3 of App Auto-Patch is now MDM-agnostic, it still works great with Jamf Pro.
The Jamf Pro-specific Script Parameters from previous versions have been replaced with an easy-to-use Configuration Profile, thanks to a robust custom schema. (If you’re unfamiliar with leveraging a custom schema in Jamf Pro, review Deploying Custom Computer Configuration Profiles Using the Application & Custom Settings Payload.)
For this quick-start, you can simply accept the supplied default values and deploy to your test Mac.
Continue reading …
1 reply
ejadadic
  • April 3, 2025
This is pure gold. Thank you Dan as always!
