Assigning Users to Devices then Smart Groups
  • October 23, 2015
  • 11 views
Is there a way to take a spreadsheet I've exported from our student information system that is a course roster of students, add a couple of fields such as device serial number and address or something then upload that to JAMF and update the inventory? Or is the only way to add users to devices is one by one inside the program? Would love to do a bulk update if possible.
1 reply
  • October 25, 2015
Check with your TAM. Ours gave us a script that you can put the device serial number in one column of a CSV, and the username in the other and it will write that information via the API.
