I'm trying to create an EA that determines if Forcepoint is running or not. I wrote the script out as a bash script first to test to make sure it returned what was needed and it works just fine. However, once I copied it over to JAMF, I always get FALSE.
I changed it to just echo the results of the command and it didn't return anything. I can't figure out why it's always returning FALSE. Am I missing something?
dlp_status=$(wepsvc --status --wsdlp)
if [ "$dlp_status" == "The kernel extension is loaded and the daemon is running. The component is running." ]; then
echo "<result>TRUE</result>"
else echo "<result>FALSE</result>"
