Auto Configure AD Macs for AEP-TLS 802.1x using Casper
  • November 24, 2011
  • 6 replies
  • 92 views
Forum|alt.badge.img+19
Initially Apple’s suggestion to use PEAP or TTLS protocols to connect Macs to corporate WIFI. Unfortunately we have a Cisco ACS server doesn’t handle TTLS and PEAP option is not on the cards due to computer cert method has been chosen for the entire site.
We wanted to implement EAP-TLS 802.1x for Mac OS 10.6.8 clients with Corporate Build (AD bound Macs) with zero user interaction. So we have automated the below actions:
On Windows Server;
Create cert request Issue cert
Export cert
Place on ftp server
On Mac Client;
Install CA Root cert
Install CA chain certs
Install machine cert
Set trust level on certs
Create 802.1x system profile
Set trusted certs for 802.1x
Set machine cert for 802.1x
Set username for 802.1x
Broken command line (confirmed by Apple this command doesn't work after 10.6.4)
"networksetup -settlsidentityonsystemprofile" (sample as below) was a show stopper.
networksetup -settlsidentityonsystemprofile AirPort /$computername.yourcompany.com.pfx somepassword
“BTW I have managed to automate in user level 802.1x User Profile and all seems to work rather smooth. But we have experienced unstable connection and required users to click connect every now and then (not ideal user experience). So we went back to drawing board again to use system level (802.1x System Profile).”
I want to automate pfx (same as p.12) formatted computer cert to be assigned to 802.1x system profile. It only works in GUI. Here are the buttons I have to click to get this to work:
Open Network Preferences => Airport => Advanced => 802.1x => Select System Profile => Select TLS => click to "Configure..." radio button
After clicking "Configure..." radio button it prompts for admin username and password. Then all works.
I had to use Apple Script UI function as in CorpWifiConnect.scpt to over come this issue. I had to create a temporary admin account for this too. Surely temp account will be deleted after the process.
Here are the steps to get Mac clients to be automated with using Casper login policy with “Once Per Computer” flag. Scoped to smart group “Mac Laptops – AD bound”.
Step1: Create 802.1x System Profile then export it as CorporateWIFI.networkConnect
Export the 802.1x system profile
in Configure Trust… select + button and choose Select Certificate From System.keychain
Step2: Package the 802.1x System Profile (CorporateWIFI.networkConnect XML file) to be imported in to Network Preferences – Airport. Then add the username with host/fqdn.company.com to authenticate to AD through ACS.
Add XML File on the package (I have positioned in /private/tmp). Named the pavkage CorporateWIFI.networkConnect.pkg
Postflight script within package
## postflight
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
##Set some variables
computername=`networksetup -getcomputername`
EAPSystemProfiles=/Library/Preferences/SystemConfiguration/preferences.plist
setuuid=`cat /Library/Preferences/SystemConfiguration/preferences.plist | grep /Sets/ | cut -c 16-51`
##Delete any previous TLS 802.1x entry to SystemConfiguration/preferences.plist
/usr/libexec/PlistBuddy -c "Delete :Sets:$setuuid:Network:Interface:en1:EAPOL:UserName" $EAPSystemProfiles
##Import 802.1x System Profile
networksetup -import8021xProfiles AirPort /private/tmp/CorporateWIFI.networkConnect
/bin/sleep 3 #allow some time
##Do a backup copy of the preferences.plist with the date stamp
cp /Library/Preferences/SystemConfiguration/preferences.plist /Library/Preferences/SystemConfiguration/preferences.plist_original_`date +%M-%H-%m-%d-%y`
##Edit preferences.plist file to add the host/fqdn to allow ACS / AD comms for authentication
/usr/libexec/PlistBuddy -c "Add :Sets:$setuuid:Network:Interface:en1:EAPOL:UserName string host/$computername.company.com" $EAPSystemProfiles
##Enable 802.1x System Profile
networksetup -enablesystemprofile AirPort CorporateWIFI
/bin/sleep 5 #allow some time
networksetup -setairportpower airport on
exit 0      ## Success
exit 1      ## Failure
Postinstall script within package
## postinstall
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
sudo rm -R /private/tmp/CorporateWIFI.networkConnect
sudo rm /$computername.company.com.pfx
exit 0      ## Success
exit 1      ## Failure
Step3: Set up a Casper Smart Group with AD Macs
Step4: Set up a Casper Policy at login – Once per computer
Scope it to Casper Smart Group “Laptops with New Build AD bound”
Add Package CorporateWIFI.networkConnect.pkg to the policy
Add Scripts to the policy
Run below script Priority Before (this will get the computer cert from FTP and set the Mac for Apple Script, also will lock the screen to prevent user interaction)
/bin/sleep 30 #allow some time for login properly
# Set some variables
# Grab hostname
# check for jamf binary
jamfbinary="/usr/sbin/jamf"
# jamf binary required to run this script
# check if jamf exists
if [[ -e $jamfbinary ]]
    then /bin/echo "Jamf binary present, continue”
    else /bin/echo "Jamf binary is not present, stop"
    exit 55
##Grab the unique computer cert from FTP
/usr/bin/ftp -i ftp://username:password@serverurl <<ENDOFCOMMANDS
get ${computername}.company.com.pfx
quit
ENDOFCOMMANDS
##Airport off
networksetup -setairportpower airport off
##Import the Cert to login keychain
security import /$computername.company.com.pfx -k /Library/Keychains/System.keychain -f pkcs12 -P mypassword
##MUST Turn on Assistive Devices for AppleScript to run properly
sudo touch /private/var/db/.AccessibilityAPIEnabled
##Create local temporary admin account to assign cert to Airport 802.1x System Profile trust
/usr/sbin/jamf createAccount -username tempadmin -realname TempAdmin -password temppassword –home /Users/tempadmin –shell “/bin/bash” -admin
/bin/sleep 15 #allow some time between accounts to ensure they create properly
/bin/echo "done creating local TemAdmin account"
# Lets lock the screen while the process is taking place to prevent user interruption.
/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType fs -heading " Corporate WIFI configuration!" -description "***IMPORTANT*** Configuration action MUST NOT BE INTERRUPTED! Please leave your MAC ON with POWER SOURCE and NETWORK CABLE attached. Process will take a MINUTE TO COMPLETE. Your Mac will RESTART" -icon /System/Library/CoreServices/Network Setup Assistant.app/Contents/Resources/Assistant.icns &
Run CorpWifiConnect.scpt script Priority After (this will use UI with Apple Script to get around the broken Apple command line to assign the computer cert to 802.1x system profile)
tell application "System Preferences"
    activate
    set the current pane to pane id "com.apple.preference.network"
    get the name of every anchor of pane id "com.apple.preference.network"
    reveal anchor "Advanced Airport" of pane id "com.apple.preference.network"
        tell application process "System Preferences"
            delay 1
            click radio button 5 of tab group 1 of sheet 1 of window "Network"
            select row 2 of outline 1 of scroll area 1 of tab group 1 of sheet 1 of window "Network"
            select row 1 of table 1 of scroll area 1 of group 1 of tab group 1 of sheet 1 of window "Network"
            click button "Configure…" of group 1 of tab group 1 of sheet 1 of window "Network"
            click button "Continue" of group 2 of window "Choose An Identity"
        end tell
            delay 5.0
            set value of text field 1 of window 1 of application process "SecurityAgent" to "tempadmin"
            delay 5.0
            set value of text field 2 of window 1 of application process "SecurityAgent" to "temppassword"
            delay 5.0
            click button 2 of group 1 of window 1 of application process "SecurityAgent"
        end tell
            activate
                    delay 1
                    click button "OK" of sheet 1 of window "Network"
                    click button "Apply" of window "Network"
                    delay 2
                    click menu item "Quit System Preferences" of menu 1 of menu bar item "System Preferences" of menu bar 1
                end tell
            end tell
        end tell
    end tell
end tell
do shell script "networksetup -setairportpower airport off"
do shell script "networksetup -setairportpower airport on"
Set Mac to reboot to avoid keyboard and mouse malfunction created by jamf screen lock (this happens some times, so we don’t want to take a chance)
Type the following in Run Command section in Advance section of the policy to delete the temp account and kill the screen lock
/usr/sbin/jamf deleteAccount -username tempadmin -deleteHomeDirectory && killall jamfHelper
Best answer by Cem
I see the scripts are broken ...I will copy and paste the AppleScript here:
tell application "System Preferences" activate set the current pane to pane id "com.apple.preference.network" get the name of every anchor of pane id "com.apple.preference.network" reveal anchor "Advanced Airport" of pane id "com.apple.preference.network" tell application "System Events" tell application process "System Preferences" delay 1 click radio button 5 of tab group 1 of sheet 1 of window "Network" select row 2 of outline 1 of scroll area 1 of tab group 1 of sheet 1 of window "Network" select row 1 of table 1 of scroll area 1 of group 1 of tab group 1 of sheet 1 of window "Network" click button "Configure…" of group 1 of tab group 1 of sheet 1 of window "Network" click button "Continue" of group 2 of window "Choose An Identity" end tell
tell application "System Events" delay 5.0 set value of text field 1 of window 1 of application process "SecurityAgent" to "tempadmin" delay 5.0
set value of text field 2 of window 1 of application process "SecurityAgent" to "temppassword" delay 5.0
end tell tell application "System Preferences" activate set the current pane to pane id "com.apple.preference.network" get the name of every anchor of pane id "com.apple.preference.network" reveal anchor "Advanced Airport" of pane id "com.apple.preference.network" tell application "System Events" tell application process "System Preferences" delay 1 click button "OK" of sheet 1 of window "Network" click button "Apply" of window "Network" delay 2 click menu item "Quit System Preferences" of menu 1 of menu bar item "System Preferences" of menu bar 1 end tell end tell end tell end tell
end tell
  • November 24, 2011
end tell
  • November 24, 2011
## postflight
pathToScript=$0
pathToPackage=$1
targetLocation=$2
targetVolume=$3
computername=networksetup -getcomputername
setuuid=cat /Library/Preferences/SystemConfiguration/preferences.plist | grep /Sets/ | cut -c 16-51
cp /Library/Preferences/SystemConfiguration/preferences.plist /Library/Preferences/SystemConfiguration/preferences.plist_original_date +%M-%H-%m-%d-%y
##Edit preferences.plist file to add the host/fqdn to allow ACS / AD comms for authentication /usr/libexec/PlistBuddy -c "Add :Sets:$setuuid:Network:Interface:en1:EAPOL:UserName string host/$computername.company.com" $EAPSystemProfiles
exit 0 ## Success
exit 1 ## Failure
  • November 24, 2011
# Grab hostname
exit 55
quit
ENDOFCOMMANDS
##Airport off
# # Lets lock the screen while the process is taking place to prevent user interruption.
/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType fs -heading " Corporate WIFI configuration!" -description "*IMPORTANT* Configuration action MUST NOT BE INTERRUPTED! Please leave your MAC ON with POWER SOURCE and NETWORK CABLE attached. Process will take a MINUTE TO COMPLETE. Your Mac will RESTART" -icon /System/Library/CoreServices/Network Setup Assistant.app/Contents/Resources/Assistant.icns &
  • July 27, 2012
  • October 25, 2012
Hi Cem.
We are looking at doing this for clients running 10.6.8 - 10.8.2 I had a couple questions about the 10.6.8 ones, hoping you might still be around and remember. From your original post:
Install machine cert Set trust level on certs Create 802.1x system profile Set trusted certs for 802.1x Set machine cert for 802.1x Set username for 802.1x Broken command line (confirmed by Apple this command doesn't work after 10.6.4) "networksetup -settlsidentityonsystemprofile" (sample as below) was a show stopper. networksetup -settlsidentityonsystemprofile AirPort /$computername.yourcompany.com.pfx somepassword
I have a functional, trusted certificate chain issued by my Win2008 CA. I've imported said chain into a 10.6.8 Mac, but when I go to set up the 802.1x (system) profile I'm confused. I shouldn't need a username/password for a system profile, do I? Isn't the point of a system profile to provide authentication at the login window/before login? Also, I can't seem to configure EAP-TLS in the network settings - when I select TLS and click configure, I get the following error:
Certificate authentication cannot be used because your keychain does not contain any suitable certificates. Use Keychain Access to import the appropriate certificates into your keychain. If you do not have the certificates required for authentication, contact your network administrator.
So the certificates I get from my CA aren't appropriate for 802.1x on a Mac (but they work on PCs) so what am I doing wrong?
  • May 9, 2013
@mlinde , sorry just seen this! No notification.....
Make sure your cert has the DNS Name as "host/fqdn.company.com". I think we had to create a new temp for the Macs
Also pay attention to this part:
