Auto Lock Time
  • July 5, 2012
  • 5 replies
  • 221 views
Hello Jamf Nation
i have a Question regarding Auto Lock
I have pushed a Configuration Profile with 2 minutes Auto Lock Time.
Now i will change this two Minutes to 5 Minutes.
When i have changed the Time in the Profile and the Profile is Pushed is in the iOS Device still 2 Minutes selected only i can manually select 5 Minutes.
It is possible to select automatically the 5 minutes on the iOS Device?
Thanks
  • November 15, 2013
I am having a similar issue. I set the auto-lock time to 5 minutes in a configuration profile. The profile gets pushed to the iPad during the Supervise operation in Configurator. No matter what, the auto-lock time on the iPads is set to 2 minutes.
I have deleted the configuration profile and rebuilt it. Same result. 2 minutes.
  • October 23, 2017
Same issue here. I also need this to work without a passcode. If I do not enter a passcode, I can go in and change the time.
  • January 26, 2018
where and how should i set this ? Apple allow us to do that ?
i didn't get any tabs to set this in jamf too.
i would like to set this to all school ipad, kids love to set auto-lock to never and it drain battery for nothing.
  • August 9, 2018
It seems that the solution to this is explained in the comment here:
https://www.jamf.com/jamf-nation/discussions/20303/ipad-passcode-auto-lock-not-working#responseChild134503
  • August 17, 2018
is there anyway to bypass the passcode setup ? because i do not want to force setup passcode on some specific ipad.
