AutoDMG 1.6 not creating Recovery Partition 10.11.6
  • December 5, 2016
  • 6 views
rqomsiya
Hi all,
I've been using AutoDMG 1.6 and have been noticing that the final .DMG does not include a Recovery partition. Has anyone seen this? I don't see it as a bug in the new 1.7 version. Any ideas?
1 reply
  • December 5, 2016
I just made a fresh image using AutoDMG 1.7 and Install macOS Sierra.app v 10.12.1. (on macOS 10.12.1)
Mounted this image in the finder, and ran diskutil list: this is the output:
/dev/disk3 (disk image):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        +38.7 GB    disk3
   1:                        EFI EFI                     209.7 MB   disk3s1
   2:                  Apple_HFS Macintosh HD            37.8 GB    disk3s2
   3:                 Apple_Boot Recovery HD             650.0 MB   disk3s3
This is what I expected, same as AutoDMG v1.6, so what is different in your case?
