Hi, we have our machines setup for autologin in all the labs, we are having a sporadic issue of some of them logging out if the machine is rebooted or idle for a long period, the "Disable automatic login" is unchecked on all machines. This has started recently and hasn't been an issue before. Is there something that I need to check. Thanks in advance
@tcarlson Do you use a Configuration Profile with a Login Window payload? In Jamf Pro 99.100 that payload template defaults to logging out users after 30 minutes, so you might want to check that setting if you are using that payload.
